VDO Wiring Diagrams? - Defender Source
Old May 25th, 2016, 10:35 PM
RBBailey
RBBailey
1965 IIa
So I bought a whole compliment of new gauges for my project. But I did not get any wiring diagrams or literature of any kind with the gauges. Not sure why.
I have found PDF's in searches, but most are not direct matches to the exact model gauge I have. This may be normal, but I have nothing to go by to know if it is.
Anyone know where I can go to see and click on a list of diagrams/instructions for these gauges?
Project:
1965 IIa SWB
Old May 25th, 2016, 10:52 PM
Most gauges I have worked with have been fairly self explanatory, but VDO vision series gauges I have bought typically come with an instruction sheet . Ground to the gauge, ground to the lamp. Power to the lamp, power to the gauge, Signal wire to the gauge. When they get complicated is when you have a tach with dip switches to set. Pyrometer leads and boost gauge tubes are also pretty self evident. The key to good operation is great grounding.
Old May 25th, 2016, 11:10 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I don't know if this will help you but here's a diagram that I made for the power wiring for the gauges.
Dash Harness by Chris, on Flickr
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old May 25th, 2016, 11:14 PM
RBBailey
RBBailey
1965 IIa
Yes. It does seem straight forward. But all new territory for me, with lots of $$$$$ invested, and no room to fail = slow and sure.
Yes that will help if I don't die of old age before getting that far! Nice looking diagram.
------ Follow up post added May 25th, 2016 08:17 PM ------
Chris. Am I right, that you have a single ground for both lighting and gauge operation?
Also, love that speedo, could not find that when I ordered!
Project:
1965 IIa SWB
Old May 25th, 2016, 11:33 PM
Yes, single ground
Old May 25th, 2016, 11:55 PM
RBBailey
RBBailey
1965 IIa
So.... I am hooking up the EGT and oil and water on temp terminals so that I can run the engine, monitor the vitals and check for leaks and such.
The ETG gauge is showing no temp response while engine is running and doing some revving.
PSI and water temp seem to be working fine.
Project:
1965 IIa SWB
Old May 26th, 2016, 08:58 AM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
You need a load on the engine to build temp in the exhaust. That is a gauge you don't need to run it and move it around your driveway.
Ryan
84 110SW County LHD
07 L322 Vogue
wiring
Vdo gps sender and vdo electronic vision plus speedometer Werrea Defender Technical Discussions 6 April 20th, 2015 05:18 PM
Wiring diagrams One Ten Defender Technical Discussions 2 January 23rd, 2012 09:48 AM
Wiring Diagrams Ian Defender Technical Discussions 5 February 7th, 2011 11:04 PM
Need wiring diagrams jaygoss Defender Technical Discussions 2 March 21st, 2010 08:44 AM
Some wiring Diagrams Mike Hippert Defender Technical Discussions 5 March 9th, 2005 11:14 PM
