VDO Volts reading high? - Defender Source
Old September 29th, 2015, 08:38 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
My VDO battery gauge shows 12 volts with the engine off but key on prior to starting...however with the engine running it is showing 14+ on the gauge...is this normal for the alternator to be pushing that much....?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old September 29th, 2015, 08:44 PM
yes!
Old September 29th, 2015, 08:52 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Fantastic!
Temperature Gague false reading trick? arbik Defender Technical Discussions 67 April 30th, 2017 09:45 PM
Vdo gps sender and vdo electronic vision plus speedometer Werrea Defender Technical Discussions 6 April 20th, 2015 05:18 PM
Some light reading for all Cirbo Misc. Chit-Chat 1 September 20th, 2007 09:47 AM
Spring Trials in Reading,PA rvrsrvc Trips, Trails and Events 0 February 27th, 2006 10:36 AM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
