VDO Temperature Sender - Defender Source
Old August 2nd, 2007, 01:56 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Hi Everybody,
I've searched and searched but I still confused about which VDO temperature sensor is the best fit for a 94 D-90 with a 3.9L. I've found three different thread types mentioned in various postings and I'm not sure which is correct. The FAQ references an eGauges.com part number (323-422) that no longer exists.
Could somebody recommend one of these senders ? I'd like to avoid having to re-tap, if possible.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old August 2nd, 2007, 07:16 AM
The 323-417 works perfectly. I just installed one a couple months ago.
Old August 2nd, 2007, 11:45 PM
chris snell
Chris Snell
87 Ex-MOD 110
Thanks, Jim. Do I need to buy their wiring kit or any of their adapters? I was hoping to utilize the existing wiring but I'm not sure if that will work.
2013 LR4
Old August 3rd, 2007, 07:34 AM
You dont need to buy a wiring kit or any adapters, you can use the stock wire, however, the I recall the end connector is different, so you might have to cut the original one off and crimp a new one on. And you will have to cut and crimp a couple connectors behind the guage so that you can plug in the existing wires to make the guage light up. No new wires, just rearranging ones already there.
Old August 3rd, 2007, 10:04 PM
61rover's Avatar
61rover
John Crouse
Based on other posts, I ordered a 323-095 for my '93 D110. Did I not get the right one? Do I need to 323-417?
Old August 4th, 2007, 12:14 AM
chris snell
Chris Snell
87 Ex-MOD 110
It's confusing. I went ahead and ordered the unit that Jim recommends. I'll report my findings here.
.This post seems to indicate two different threadings. Really confused.
2013 LR4
Old August 4th, 2007, 09:17 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I put in the 1/8 NPT sender in to my 110. I had an adapter machined from a bolt I got at the hardware store. Cost me 9 bucks.
Old September 23rd, 2007, 10:50 PM
61rover's Avatar
61rover
John Crouse
VDO Temp Sending Unit for '93 D110
It's definitely the 323-417. Installed it this evening. Works like a charm.
Temperature Gague false reading trick? arbik Defender Technical Discussions 67 April 30th, 2017 09:45 PM
Tdi VDO oil pressure sender help Uncle Douglas Defender Technical Discussions 15 August 1st, 2014 12:08 PM
200tdi VDO Sender Part Numbers Wolf Fabrication Defender Technical Discussions 6 February 26th, 2011 04:55 PM
Has any one installed a VDO oil pressure sender on the '97 - 4.0? LenB Defender Technical Discussions 8 March 29th, 2010 01:30 PM
Temperature sender thread type/pitch? Neo Defender Technical Discussions 4 March 9th, 2006 02:40 PM
