VDO Temp Gauge issue - Page 2 - Defender Source
Old August 6th, 2014, 10:12 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Are you using 16 ga to the sender too, it needs it.
Old August 6th, 2014, 10:14 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
i'll try that when i get back at it.
awful lot of rewiring for what's supposed to be plug and play.
but i get it.
Old August 6th, 2014, 10:16 PM
There is no need for a bunch of wiring. You have a dirty ground somewhere.
Old August 6th, 2014, 10:19 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
That's what I'm thinking too.
And I have a thought on what that might be.
Just say one went back to stock, it's a female bullet connector on the OEM sender correct?
Old August 6th, 2014, 11:24 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The gauge draws basically no power so your wiring would need to be seriously messed up to have a serious loss from the loom to the gauge.
If the (+) current drops below 11.5 volts which is easy say on the green circuit with multiple (+) devices, then the gauge readings will NOT be accurate.
If this is your definition of "seriously messed up" then the (+) draw has reached that threshold.
I accurately described the optimal way to wire a VDO gauge in post 12 and guarantee that if the gauge is wired as suggested and the gauge and sender are in compatible matched sync then the readings will be accurate.
It is not only possible, but probable in this case that a gauge with a perfect single ground and multiple devices wired on the same (+) circuit can and will provide inaccurate readings.
To be 100% positive of accuracy you need to wire the gauge accordingly to the manufactures recommendations described in post 12.
RDavisinVA
VDO Temp Gauge Wiring javelinadave Defender Technical Discussions 33 September 8th, 2017 10:56 AM
VDO Temp Gauge aaronlam For Sale - Parts 0 October 13th, 2013 05:50 PM
Temp gauge replacement by VDO ditskovich Defender Technical Discussions 1 April 16th, 2011 12:32 AM
Need tech specs on vdo temp sensor and gauge airbornrover Defender Technical Discussions 0 May 23rd, 2009 11:24 PM
VDO temp gauge sflash868 Defender Technical Discussions 3 May 31st, 2006 09:36 AM
