VDO temp gauge - Defender Source
Old May 31st, 2006, 02:26 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
VDO temp gauge
I know a lot of people here have converted the temp gauge to VDO vision series and I would like to perform the same modification in an effort to troubleshoot some weird readings i get from the current gauge. (plus it looks better) Does anyone have a write-up with pictures regarding the installation process and part numbers? I searched around and found one post saying I need a GM sender? I think i'm a little confused regarding what modofications need to be made in order to get the gauge to work. I apologize if this topic has been beat ot death...
Old May 31st, 2006, 08:17 AM
btate
Bryan Tate
d90
I just did this last week for my 94 d90.
The wiring was simple, but it took me 3 tries to get the correct sender....even now some threads are showing on the sender when I installed it.
I went with the M16 x 1.5 sender. It was the only one I could get to thread in. I called VDO tech support and they said not to worry as long as it doesn't leak....
It seems to register correctly at this point
Email me if you have any questions, as it is still fresh in my mind.
Old May 31st, 2006, 09:24 AM
Etrier
Jonah Thompson
1994 D90 ST
any chance you have the part numbers available? I have a 94 D90 and am about to do this. Any other issues/problems?
Old May 31st, 2006, 09:36 AM
btate
Bryan Tate
d90
Temp Gauge: 250F/150C Range (#310 105)
Temp Sender: 250F/150C Range (#323-417)..but the threads will stick out some
It is a straightforward swap out, there is a long writeup...search "dim lights"
diameter of stock temp gauge naeirie Defender Technical Discussions 2 March 2nd, 2005 06:34 PM
Temp Gauge dbwitt Defender Technical Discussions 5 March 18th, 2004 08:14 PM
temp gauge ron Wanted 0 December 10th, 2003 12:44 PM
Temp gauge on H perminently ron Defender Technical Discussions 1 December 8th, 2003 05:27 PM
