VDO Speedometer Connector - Defender Source
Old October 4th, 2013, 08:30 AM
My speedometer took a shit, so I ordered a VDO vision series replacement. The back of the speedometer has a place for a multiplug, which is not included. I searched the forum and did see a part number for the connector. With a good search, I found http://www.jegs.com/i/VDO/918/240-02...oductId=760377 but it does not look like it will work in the back of the speedometer. Does anyone have the correct part number?
A pic of the speedometer for reference...
Old October 4th, 2013, 09:21 AM
Check this out!
http://www.defendersource.com/forum/...ead.php?t=7156
Old October 4th, 2013, 09:40 AM
I saw that thread in my search, but didn't think it was relevant. That will be helpful for wiring it up. I didn't realize the connector is the same as a 97 D90. I didn't see a part number for a replacement connector in the Land Rover D90 electrical library. Did I miss the part number in that thread?
Old October 4th, 2013, 10:31 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Is there a reason you do not want to use push connectors ? You could have it done today if you just use the push connectors.
legend in my own mind
Old October 4th, 2013, 10:57 AM
Female spade connectors? I think that will look a little cheesy in my opinion. If its available I'd rather use the correct connector.
Old October 4th, 2013, 11:19 AM
I've looked before and never been able to find one.
Old October 4th, 2013, 12:26 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Everyone else has done spade connectors and we don't have a rash of wiring problem threads, so I think it's pretty safe.
Old October 4th, 2013, 02:42 PM
I'm not worried about having an electrical issues, I'd just rather have the correct connector if its available. FWIW I check through all of our replacement connectors at the dealership, and we don't have any.
------ Follow up post added October 4th, 2013 02:42 PM ------
Did you ask VDO by any chance?
Old October 4th, 2013, 02:55 PM
http://www.summitracing.com/parts/vdo-240-053/overview/ ?
The only other alternative is a six-wire connector. Does that speedo have an integrated odometer?
------ Follow up post added October 4th, 2013 03:03 PM ------
Why do you think it will not work? According to VDO, that is the correct connector...
Old October 4th, 2013, 03:39 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I see
You are building an Apple computer.
I may have one of these connectors used.
What do you have to trade?
Old October 4th, 2013, 03:52 PM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
The socket housing moulded (molded ) into the back of the VDO speedometer, looks like an AMP Fastin/Faston 6.3mm (") terminal connector.
It looks as though it's moulded to accept both the 6-way and 8-way female connector, depending on the number of terminals used by the speedometer.
AMP Fastin/Faston connectors are available from most Auto-Electrics sellers in the UK, British Wiring do them in the US -
http://www.britishwiring.com/6-Way-1...tor-p/c846.htm
http://www.britishwiring.com/8-Way-1...tor-p/c848.htm
Paul.
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old October 4th, 2013, 07:00 PM
Just based on the picture. It doesn't look like it has the notches like the back of the Speedo does. I'll order one and see what I get.
speedo
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
New Gears and WOW, 10 mph? mdmccallum Defender Technical Discussions 26 December 1st, 2011 03:50 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
VDO Speedometer mgrgpg Defender Technical Discussions 6 December 17th, 2003 09:26 AM
