VDO Speedometer - Defender Source
Old January 10th, 2016, 10:15 PM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
VDO Speedometer
Know this has probably been covered but getting no where . . .
Have an 89 110 that just put a 200tdi/R380 and has LT230. Have the YBE 100530 connector. Believe the outer 2 go to pins 7 and 8, but not registering anything. It does come on, lights up, just shows 0, when I tried to set it an "L" came up but after I hit it after going 1 mile still at zero. Gage needle never moved . . . Thoughts?
Old January 11th, 2016, 11:43 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I still need to program mine so am interested in figuring out how exactly these work with a VDO Speedo.
Are you sure you have the YBE100530? Green with 3 pins and I believe it has a Hall Effect sensor built into it.
The YBE100430 has 2 pins and Variable Reluctance (VR).
I have to recheck my wiring but I used Tom's posts as a guide: http://www.defendersource.com/forum/...r-26385-3.html
ID:	139109   Click image for larger version
Old January 11th, 2016, 11:50 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Rereading Tom's and John's posts I now know I wired my incorrectly and will have to revisit. (Makes sense why it didn't want to program when I tried).
Curious as what the plug from the YBE100530 to VDO wiring scheme should be.
Old January 11th, 2016, 01:51 PM
wanabewheelin
Michael Sword
Hell, now that you mention it I'm not sure . . . Galpin brought it over and installed it as mine didn't ship in time. Will have to take a look when I get home.
Old January 11th, 2016, 02:22 PM
Per the posts linked above.
VDO pin 2 (regulated +12V) connect to YBE100530 pin 1
VDO pin 3 (ground) connect to YBE100530 pin 2 and ground.
VDO pin 8 (sensor signal) connect to YBE100530 pin 3
I also believe this type of hall effect (open collector output) needs to bridge VDO pin 6 to VDO pin 8.
Old January 11th, 2016, 02:29 PM
wanabewheelin
Michael Sword
if it were a YBE100540, what would be the difference in wiring?
Old January 11th, 2016, 02:43 PM
The two leads connect to VDO pins 7 and 8 if it is being used by itself. If including an EFI ECU in the circuit is is different and explained somewhere else around here....
Old January 11th, 2016, 02:49 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks John - the 12V piece has me confused. I checked the VDO speedo this morning and Pin 2 does not have any power (gauge powers up power to Pin 4) according to my test light. Should I split a 12V source to power Pin 2 and to Pin 1 on the YBE100530?
Any help would be very appreciated. Thanks
Old January 11th, 2016, 02:51 PM
wanabewheelin
Michael Sword
copy, no ECU, just fat fingers that have no clue what they are doing . . . too many wires . . .
Old January 11th, 2016, 03:04 PM
Pin 2 on the gauge should output power when the gauge is powered up. Pin 4 is the input power. You could just run straight switched power to the sensor pin 1 and not connect anything to pin 2 of the gauge.
Old January 11th, 2016, 04:07 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks - I will do some more testing and see what is going on. Like you said I could just run power straight to the transfer case sender.
Old January 12th, 2016, 12:09 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Here is the wiring for YBE100540 with the vss feed to the ECU (such as for NAS 1994). The resistor is a 120 ohm. http://www.defendersource.com/forum/...2&d=1389196177
And for the YBE100530, I believe Johns post is correct. On VDO, Switched power to pin 4, pin 2 power out to ybe power in, ground to pin 3 and ybe ground, and the signal wire from ybe jumped to pins 6 and 8. Here is a diagram, your wire colors may vary. http://www.defendersource.com/forum/...8&d=1339329614
I have a ybe100540 sitting in a box along with my VDO. I haven't installed it yet so the above is all the information from reading all the posts about it. I have every reason to believe they are correct as they are the latest consensus and no one chimed in further after these wiring methods came out. Still, it is Theory until mine is up and running so I hope it is correct :-)
Old January 12th, 2016, 07:52 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by Davis View Post
Here is the wiring for YBE100540 with the vss feed to the ECU (such as for NAS 1994). The resistor is a 120 ohm. http://www.defendersource.com/forum/...2&d=1389196177 And for the YBE100530, I believe Johns post is correct. On VDO, Switched power to pin 4, pin 2 power out to ybe power in, ground to pin 3 and ybe ground, and the signal wire from ybe jumped to pins 6 and 8. Here is a diagram, your wire colors may vary. http://www.defendersource.com/forum/...8&d=1339329614 I have a ybe100540 sitting in a box along with my VDO. I haven't installed it yet so the above is all the information from reading all the posts about it. I have every reason to believe they are correct as they are the latest consensus and no one chimed in further after these wiring methods came out. Still, it is Theory until mine is up and running so I hope it is correct :-)
Thanks Davis - still puzzled why I wasn't getting power out of Pin 2 on the VDO. Going to pull it out of the dash and test on the bench.
Old January 14th, 2016, 09:46 AM
wanabewheelin
Michael Sword
John, finally have this sorted . . . all info above is correct, had 2 wires switched . . . found this site for testing VDO gauges
http://www.bugsandbuggies.com/pdf/vdo/0-515-012-178.pdf
Wiring of Sender to Speedo:
Red on sender to term #2 on speedo
Black on sender to term #3 and ground
Off-white on sender to term #6 and #8
Switched 12v to term #4
Testing Hall Effect Sender:
Turn ignition key .ON.. Put red lead of voltmeter to term #2 and black lead to
term #3. You should have between 5-12volts dc.
With the key .ON., leave the black lead on term #3 and put the red lead on term
#8. Remove the sender from the transmission. Rotate the square drive shaft in
the sender very slowly with your fingers. You should see the voltmeter pulse
from 0-4 volts dc. (0-4-0-4-0)
If it pulses, the sender is working properly. If the voltmeter stays a constant 5
volts dc, the sender is defective.
There is more info for other VDO gauges on the link . . .
Appreciate the help!!
speedo
Vdo gps sender and vdo electronic vision plus speedometer Werrea Defender Technical Discussions 6 April 20th, 2015 05:18 PM
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
VDO speedometer sender oldscratchggf Defender Technical Discussions 0 October 19th, 2006 08:30 PM
VDO speedometer wiring cameltrophy90 Defender Technical Discussions 2 April 10th, 2006 01:01 PM
VDO Speedometer mgrgpg Defender Technical Discussions 6 December 17th, 2003 09:26 AM
