VDO Speedo Power and Ground - Defender Source
Old November 26th, 2011, 02:19 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
I have read all the VDO speedo posts and people always talk about the power and ground but never say where they actually ran the wires. I have everything pretty much wired up with the hall sensor but I need 12v switched power source. Can i splice into the back of the iginition switch? if so which wire of the 4 wires is the power? Also where is the best place to ground it? The instructions say where the ground for the battery is against the frame is best. Anyone know where that is?
Any suggestions from anyone who has installed one of these would be great.
B
Old November 26th, 2011, 04:48 PM
There is a common correct wire for instrument gauges and ground. See the other instruments. You should just be moving the lead from the old instrument to the new.
Old November 26th, 2011, 04:52 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ya thats true of all instruments except for the speedometer which is being changed from mechanical to electrical. So really this is just for anyone who has a 94 and has switched over to an electrical speedo.
Thanks for your response.
B
Old November 26th, 2011, 05:24 PM
Make a wire from the power of another instrument to the speedo....
Old November 26th, 2011, 05:28 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Can I do that? Obviously, I am an electrical idiot. Won't it draw too much power or mess up the other instrument?
Old November 26th, 2011, 05:38 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
To be honest, the easiest way is to just daisy-chain it to the next gauge over for both power and ground. The factory speedo is mechanical, but all your other factory gauges are electrical, so they will all have power and ground on them. It won't overload anything, the gauges don't use very much power at all.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 26th, 2011, 05:40 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Gracias fellas. If it requires bolting and unbolting I can do it. Electrical work always scares me.
B
Old November 26th, 2011, 07:03 PM
No, it will be fine.
Old November 26th, 2011, 09:14 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It is a super simple job. The switched power lead should be a green wire with a white stripe. Ground is the black wire. As mentioned above you can open up the gauge pack and find these wires on the other gauges. You will also have a lighting harness so do not connect to those wires. They make a wire crimp on connector that you can use to connect the new wire to one of the existing wires. That is the easiest way but a better way would be to cut and splice with crimp shrink rap connectors.
Land Rover 110
speedo
New Gears and WOW, 10 mph? mdmccallum Defender Technical Discussions 26 December 1st, 2011 03:50 PM
Power Leather Seats For Defender Free bitz For Sale - Parts 4 September 24th, 2009 07:32 PM
Looking for a Good Ground Arnzo Defender Technical Discussions 3 November 27th, 2007 11:42 PM
ground up build advice needed. mountainviewrover Misc. Chit-Chat 16 November 8th, 2007 08:28 PM
Replacing ground wire questions vesparover Defender Technical Discussions 1 October 27th, 2003 04:01 PM
