VDO Speedo Gurus, please chine in... - Page 3 - Defender Source
Old February 15th, 2014, 02:57 PM
Lee
Lee O
95 NAS D-90 300Tdi
They programmed the speedo before shipping it. Not sure if they did it or rec'd it from VDO that way.
Old February 15th, 2014, 06:01 PM
I'm pretty sure they have a way of writing a mileage to the prom as long as it's larger than the previous version, and don't do it the hack way.
Originally Posted by pendy
I'm here for the D's
Old February 15th, 2014, 06:05 PM
i'm sure they do ... I'm just suprised how difficult it seems to be able to find info on how to do it ...
Old February 15th, 2014, 06:07 PM
I am guessing it's a combination of a easy money making opportunity and concerns about fraud if it's super easy to do.
Old June 13th, 2014, 06:05 AM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
My 95 NAS upper speedo cable took a crap and after digging thru the pile of parts between the transfer case and speedo, I plan to switch to the VDO with transfer case mounted VSS.
I am thinking of getting the YBE100530 instead of the 40 and am wondering if The wiring diagram Red posted in #33 and the 120 Ohm .25 Watt resistor are the same for this VSS.
Also, has anyone been able to program the odometer other than having it done from the likes of Egauges?
Any input is appreciated
Old June 13th, 2014, 07:55 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
If you order from Hollywood Speedometer they will program the odometer for free.
Old June 13th, 2014, 08:50 AM
hoxie173's Avatar
hoxie173
Matt Hawkes
1959 S2
So i finally managed to eliminate all the speedo cables and the VSS in my truck and replace it with a YBE10040 and a VDO speedo. The trick was to run a resistor inline with the ECU feed ... this limits the current and prevents the YBE10040 burning out. I used the resistor from the old VSS which i extracted during open VSS surgery. Tapping into the other side I ran a wire up to the speedo. Grabbed a 12v feed from the ones feeding into the other dials and attached a ground.
A few minutes calibrating against the GPS and voila!
I just did one of these last week and was a little confused where the resistor went as Jason has it inline with the ECU feed and Red's diagram shows it after the VSS. I ran it inline with the feed and no problems yet.
Old June 13th, 2014, 12:41 PM
The magic of electrics is that it doesn't matter ... As long as it's in line somewhere on the circuit it will have the desired effect.
Old June 13th, 2014, 07:43 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Will the 530 work the same way?
Using the same resistor?
Old June 13th, 2014, 08:18 PM
The other sender is a Hall effect sensor. It won't work with the EFI. It will work with the speedo by itself and no resistors are needed.
The resistor is needed only when connecting to the EFI as it is drawing too much current when sampling the signal
Old June 13th, 2014, 08:22 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Thanx Red! Just the answer I was looking for.
I will stick with the 40 and do the resistor.
Old June 13th, 2014, 08:35 PM
Forget the rest, go gps
http://www.partdeal.com/vdo-gps-spee...RHPKLBml_D_BwE
Old June 13th, 2014, 08:38 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Don't I need the vss signal for my petrol ecm?
Old June 13th, 2014, 08:44 PM
Yes my brother but whats that got to do with your speedo? No need to unplug the vss signal routed to the ecu.
Whats cool about the gps based speedo signal is that its always right regardless of tire size etc.
Old June 13th, 2014, 08:49 PM
Iamkraig's Avatar
Iamkraig
Kraig
1987 defender 110
Hmmm
Didn't think about that. Had an all or nothing plan stuck in my melon.
That may be the plan.
Thanx
Old June 13th, 2014, 11:30 PM
Hmmm Didn't think about that. Had an all or nothing plan stuck in my melon. That may be the plan. Thanx
As long as you don't live in a built up area like NYC such a thing should be fine. In NYC it would suck big time ... The only way you'd know your speed is from the writing on the moving violation.
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
VDO Speedo help timtimtj Defender Technical Discussions 6 October 24th, 2010 10:16 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
VDO speedo for sale vlocci For Sale - Parts 2 January 9th, 2004 11:32 AM
