VDO Speedo and YBE100540 for ROW - Defender Source
Old September 8th, 2013, 01:23 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I have searched and found reference but not a solution to the problem I have. The speedo sensor (YBE100540) has a much smaller key then the original speedo cable for my ROW 110. My original attempt at a fix worked for about 500 miles which was to put a piece of heat shrink on the key to enlarge the dimensions. Is there a different speed sensor with a larger key to insert into the LT230? Do I need to replace the speedo drive on the LT230 with a later type that is smaller? Engine, trans and transfer case appear to be out of a 92 or possibly 93 200tdi spec defender.
Ryan
84 110SW County LHD
07 L322 Vogue
Old September 8th, 2013, 03:18 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I had the same problem with mine, I went to Industrial Metal Supply where they had small metal square tubing. Bought a stick of the size that fit snugly on the sensor, crimped it down a little, and put it in.
No problems so far.
Old September 8th, 2013, 03:34 PM
I've run the small peg in the large hole as is and it worked fine.
Old September 8th, 2013, 07:38 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Mine slips without the spacer and only shows about 1/2 speed/inconsistent in the speed indicated.
Ryan
84 110SW County LHD
07 L322 Vogue
Old September 9th, 2013, 12:31 AM
Neill,
THANKS for that idea. I completely forgot about the small brass tubing selection at Ace. I have had the exact same problem and my shims all ended up failing quickly.
speedo
Can Somone Confirm - VDO gonzanc Defender Technical Discussions 9 December 31st, 2012 03:31 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
