VDO SPeedo - Page 2 - Defender Source
Old May 1st, 2011, 09:28 PM
Flash memory.
Old May 1st, 2011, 09:31 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I just started this exact same conversion today. Pulled out the cable, put in a sender Josh (crash303) had laying around from his 97. Didn't even think to compare the speedo cable size to the sender. I guess we will see what happens here in a few days when I have everything buttoned up.
I am also adding an EGT gauge and making most of the warning lights work for once, so lots of wiring going on.
Old May 3rd, 2011, 08:11 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
VDO Speedp finally in!
Had been putting this off for a while, put it in last night.
Its awesome having accurate speed and distance and no more jumping needle.
Very easy install, used the VDO hall effect 3 wire, the plug from the other thread, and the 120mph Speedo.
Super easy to set up, looks so much nicer.
I may have to get rid of the TD5 Speedo in favor of one of these as well!
Old May 21st, 2011, 02:35 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
So I am doing this same thing on my NAS 94. Where am I picking up power from? They say to go to a switched source on the ignition or something, but I was wondering if anyone had a suggestion for the best place where to draw the power from?
Old May 21st, 2011, 03:18 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
Sorry if I missed it but what is every doing with the speed sensor? My 94 d-90 has one so are you butting the sender after the speed sensor?
Old May 22nd, 2011, 12:59 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I ran all 3 wires to to the dash. My green sender had 3 +,-, and the signal. I believe.
But mine is an 85 with no computer worries speedo wise.
Old May 22nd, 2011, 02:17 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My stock one has three but they are different. One big one for speed sensor and two more, one for each bulb. So by installing the new YBE100540 sensor I can now get rid of the old speed sensor? The VDO will use a regular electrical cable for signal.
Old May 22nd, 2011, 06:07 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My stock speedo has a thick speedo cable that goes from speedoto one end of a box attached to the chassis (see picture 1). There is a yellow cable exiting the rear of thus box and it goes into the transfer case (see picture 2). 3rd and 4th picture shows the YBE100540 sensor.
My question is: Do I rip all this old stuff out? Is that box on the chassis needed for the new set up? Here's what I think I'm supposed to do but I would love someones blessing on this before I do something I'll regret:
I think the yellow cable is removed and the new sensor is attached to the tranny using bolt that you can barely see behind the yellow cable that holds the cable into the tranny. That bold goes through that hole in the sensor and the pin on the sensor goes into the tranny. Is this correct?
Then I need a male connector to plug into the sensor and run an electrical wire back to the new VDO speedo bypassing the old box that is attached to the chassis. Can I remove that box completely? Can someone tell me the part# of that male connector? Nothing in the manual or ebay.uk.
ID:	38984   Click image for larger version
ID:	38986   Click image for larger version
Old May 22nd, 2011, 09:21 PM
How would one make this work with the later DII style t-case
Old May 22nd, 2011, 09:54 PM
The box is for the V8 EFI ECU speed signal. If you have installed a 300TDI, you do not need it. So yes, take everything out, put the YBE100540 (or YBE100530) sender directly into the transfer case and run wires to teh VDO speedo. As per the other thread, the wiring plug is STC4637 (plug for stop lights) for either speed sender.
------ Follow up post added May 22nd, 2011 07:56 PM ------
If you have a case without the speedo gear output, then you need to change the rear output housing.
Old May 22nd, 2011, 10:21 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
That's what I thought. Thanks! You're right. It was originally a V8 but was later converted into 300tdi. It appears that they were able to reuse that V8 ECU speed signal "box" with the R380 as that is how I currently get my speedo reading.
Old May 22nd, 2011, 11:12 PM
You should be able to actually just send the "box" signal to the VDO speedo.
Old May 22nd, 2011, 11:21 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Really? The VDO doesn't have a connector for that fat speedo cable.
Old May 23rd, 2011, 12:29 AM
I do not understand the question?
You have two choices...
1) Leave everything as is and run wires from the existing VSS box to the VDO speedo.
2) Remove the speed cable from the transfer case and install YBE100540 or YBE100530 and run wires from it to the VDO speedo.
Old May 23rd, 2011, 12:57 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Is there a place to attach the wires on the old VSS box? There's only a fat speedo cable coming out of each end. I already bought the YBE transducer so if I can't find a place to attach wires on the VSS box I will go with option 2).
Old May 23rd, 2011, 01:11 AM
Yes, there should be wires and a connector. The box was the vehicle speed sensor for the V8 computer.
Old May 23rd, 2011, 10:43 AM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
So I am using Hans' suggestions http://www.defendersource.com/forum/...3&postcount=83.
I am all done except the final step.
"Install, wire and calibrate the new speedo as per the instructions that came with it."
My sender has three wires, white, red and black. The instructions state the white wire splits and goes to pin 6 and 8. The red wire says to go to a 12/24v switched power source. I was wondering if anyone has suggestions on which is the best power source to wire to? Like specifically which wire to tap into. Also the black wire goes to pin 3 i think and then to a ground. What is the best way to ground this wire?
B
Old May 27th, 2011, 06:51 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
That makes sense. So I would use the wiring meant for the CPU? See attached image.
Name:	Screen shot 2011-05-27 at 3.45.18 PM.jpg
Old May 27th, 2011, 07:27 PM
navydevildoc
Neill Thornton
Yup. Those two wires coming out of the speed box go to the back of the VDO speedo. Follow the directions for the "induction sensor", the only one with 2 wires.
Old May 27th, 2011, 07:30 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
So I just unplug #1 and run #7 to the speedo?
speedo
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
Speedo correction d90Monkey Defender Technical Discussions 2 April 21st, 2004 12:05 PM
VDO speedo for sale vlocci For Sale - Parts 2 January 9th, 2004 11:32 AM
