VDO Programmable Speedometer Upgrade Question - Defender Source
Old October 2nd, 2012, 05:05 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
(http://www.egauges.com/vdo_ind.asp?T...ion&PN=437-155)
Per, http://www.defendersource.com/tech/speedometer_replacement.html , does it require the replacement of the 94 VSS with the 97 VSS
( http://www.roverparts.com/Parts/YBE100540G.cfm
, http://www.roverparts.com/Parts/YBE100540HRK.cfm) ? Do you attach it directly to the transfer case removing the short cable that attaches the 94 VSS to the transfer case? If so, are the two wires split: one set to the speedo and one to the ECU?
Dan
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old October 5th, 2012, 05:11 PM
dsh12
Daniel Hayes
Dan
Dan
speedo
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
New Gears and WOW, 10 mph? mdmccallum Defender Technical Discussions 26 December 1st, 2011 03:50 PM
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
VDO Speedometer mgrgpg Defender Technical Discussions 6 December 17th, 2003 09:26 AM
