VDO part numbers - Defender Source
Old November 5th, 2007, 05:42 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
VDO part numbers
Found this online...very useful:
300 Tdi:
350-104 2 1/16 80 PSI Elec. engine pressure gauge Vision $25.75
360-006 Pressure Sender: 0-80 PSI/5 Bar - M10x1K - 7.0 PSI $28.37
333-156 2 1/16 4,000 RPM Tachometer Vision $74.81
310-105 2 1/16 250F Elec. engine temp gauge Vision $25.55
323-095 Temperature Sender: 250F/120C - 1/8-27 NPT - $7.31
310-153 2 1/16 250F-1650F Pyrometer (EGT) Vision Marine $153.75
1994 3.9 V8
323-417 Temperature Sender: 250F/120C - M16x1.5 - $18.82
360-009 Pressure Sender, 0-80PSI/5 Bar - 1/8-27 NPT $33.34
5-1/8 F50G-S Adapter Fitting: Parker Hydraulics - $11
Old November 5th, 2007, 10:52 PM
Yep, you either found that here or at lr4x4.com - thats my list
Old November 6th, 2007, 02:27 PM
D90user's Avatar
D90user
steve
Thanks for that Jim... I just wanted it to be easily searchable
Old February 24th, 2009, 06:00 PM
Jim C Does this fit the Tdi with no adapter ? Read where you bunged your truck and wasn't sure if that was a V8 thing or Tdi or both ?
Would prefer something that simply threads in as opposed to bung welding.
Old February 24th, 2009, 09:17 PM
V8 Yeastie got the adapter, the pressure sender threaded right into the tdi. Its a pretty recent build-date Tdi, like 2002 or 2003.
Old July 26th, 2009, 03:23 PM
JRW's Avatar
JRW
94 D90 ST #1247
Just ordered the Temp sender and gauge for my 94 3.9L per the information above. Fingers crossed for fit.
Please chime in if I should cancel the order.
Old May 16th, 2014, 05:22 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Updating this thread. I ordered the 323-095 sender and I don't believe that this is the correct one. I haven't tried the fit yet but this 323-095 uses a "Delphi Packard"-style connector:
You connect to it with a variant of a spade connector that looks like this:
It's weird and I've never seen that style of connector before. My current sender uses a plug-type connector that looks and works like a small spark plug boot.
I'm trying to hunt down the correct style of sender and will update this when I find it.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old May 16th, 2014, 05:51 PM
chris snell
Chris Snell
87 Ex-MOD 110
Ok, strike that. This will take a spade connector but only ones that are slotted so that the post can slide through. The spades that are enclosed in a rubber sleeve or coating won't work.
2013 LR4
Old May 16th, 2014, 06:04 PM
I just "crimped" both ends of the female spade connector with pliers. It's going nowhere.
Old July 1st, 2014, 09:46 AM
flounder
Chad Hamon
95 Black ST
will the above part numbers work on a 95 NAS defender? Just want to make sure before I order. Also, is it a pretty straight forward install?
Old July 1st, 2014, 10:15 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
For those requiring an adapter to clear the injector lines when using the VDO 1/8 npt sender and switch, I found this: http://www.mscdirect.com/product/details/84433465
Probably overkill, but I was concerned about the durability of the typical brass gauge adapters from VDO, AutoMeter, etc. on a diesel and found this Voss industrial adapter. It is zinc steel, larger than the brass adapters and seals on the male side with a crush gasket and o-ring. Appears to be a quality product.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
part
200tdi VDO Sender Part Numbers Wolf Fabrication Defender Technical Discussions 6 February 26th, 2011 04:55 PM
Part numbers for early 90? dave_lucas Defender Technical Discussions 2 July 4th, 2009 04:12 PM
Roll Cage Rubber Seals Part Number(s)? newfD90 Defender Technical Discussions 4 January 11th, 2008 04:33 PM
rivet part numbers? mattdh Defender Technical Discussions 0 October 29th, 2004 03:09 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
