VDO Oil pressure adapter - Defender Source
Old November 10th, 2007, 01:12 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Does anyone have an online source for the 5 - 1/8 F50G-S Adapter fitting from Parker Hydraulics? Thanks.
Old November 10th, 2007, 05:21 PM
Chris - I couldnt find that part when I went looking, so I pulled the old sender, punched out the center, and a local hyrdraulics shop welded an adapter onto the old sender core - it works like dream and cost less than 10 bucks.
Old November 10th, 2007, 09:17 PM
Grover's Avatar
Grover
Thumbs up
Chris,
I got mine from http://www.cincinnatihose.com/
Good luck...
Old November 10th, 2007, 10:14 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Thanks. I will give them a try.
Old November 13th, 2007, 04:10 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
I think I found a fitting (maybe it was a similar temp sender) with the same outside dia thread and drilled and tapped the inner thread. They're brass, so easy to do.
Old November 13th, 2007, 05:39 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Still haven't sorted out a source. Just hate to drill out a good pressure sensor.
Old November 23rd, 2007, 10:09 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
or, even easier, take out the plug bolt that's in the second hole on the oil pump... drill it out and tap the threads, then put it back in.
Cost $0 if you have a drill press and a tap set. That's what I did & it works great.
Old December 10th, 2007, 01:54 PM
texasdefender110's Avatar
texasdefender110
T.J. D...
NAS Defender 110
Austin area source
I bought my #5 o-ring boss to 1/4" NTP adapter from Capitol Bearing, www.capitolbearing.com, in Round Rock. Then I bought a 1/4" to 1/8" bushing. The part number for the straight adapter is 2216-4-5s. The FAQ indicates they will ship parts.
Fightin' Texas Aggie Class of 1998, Whoop!
Has any one installed a VDO oil pressure sender on the '97 - 4.0? LenB Defender Technical Discussions 8 March 29th, 2010 01:30 PM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
