VDO Odometer ? I HAVE SEARCHED - Defender Source
Old June 18th, 2009, 10:32 AM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
My original Speedo/Odo in my 94 D-90 has gone bad and I followed the instructions and ordered everything from egauges. No problems so far. The only issue now becomes that I would like to increment the odometer to match what is on record so I don't make the vehicle illegal and so I don't have to go through having the registration, title, etc. stamped and a sticker placed on the door as notification that the odometer reads incorrectly . Any ideas if this is a possiblity with the VDO Vision gauge? Instructions would nice.
S-P
Old June 18th, 2009, 11:01 AM
You could probably take it to a speedo shop.
Old June 18th, 2009, 11:13 AM
madcowdungbeetle
Carter
S-P
If you can get your hands on a signal generator, you should be able to run the mileage read out up to where you need it.
Old June 18th, 2009, 12:12 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
IF you buy the speedo from noth hollywood sped shop, they set your mileage for free on your new speedo
Legend in My Own Mind.
Old June 18th, 2009, 04:26 PM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
So after many hours on the phone with FL HSMV it turns out that as the vehicle is over 10 years old it doesn't matter that the odometer is changed. I will just need a full disclosure at the time of the sale.
With regard to the VDO gauge egauges.com and VDO said there is no way to set it, but other sources have said as indicated by madcow that you can connect a 12 volt source and clock it up.
So I'm leaving it at zero and just taking the exemption that FL allows and maintaining all documentation of speedo/odometer purchase, date of install, etc.
Hope this helps anyone else who had similar questions eventhough the answer probably doesn't apply unless you are in FL.
S-P
Old June 18th, 2009, 04:41 PM
Applies in PA >10 years is federal exemption but other states may have stricter rules. Save the old odometer and give it to the new owner as evidence of true miles.
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
Odometer reads 76% actual miles stevewhitaker Defender Technical Discussions 4 January 21st, 2006 06:07 PM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
Can anybody do a Vin Check for me? Quimbola Misc. Chit-Chat 7 February 18th, 2004 06:24 PM
