Vdo gps sender and vdo electronic vision plus speedometer - Defender Source
Old April 20th, 2015, 01:28 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
i just installed the vdo electronic speedometer vision series and the vdo gps sender. I don't know that I am impressed so far. The speedo seems slow to react. I set the speedo for 200k pulses and have the gps on top of the dash. Anyone have a similar experience? I hooked the gps green wire to terminal 8. Speedo is 437-158.
Old April 20th, 2015, 06:12 AM
BlackField's Avatar
BlackField
Oscar
D110
I have pretty much the same set up. Just wired the connectors for both the speedo and GPS unit yesterday. I left the GPS harness pretty much full length so if it doesn't work by the rear view mirror I can run it to the plastic vent cover on the left fender.
On a side note, are we sure it's a slow reacting speedo and not a slow accelerating Defender?
Old April 20th, 2015, 11:16 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
Originally Posted by BlackField View Post
I have pretty much the same set up. Just wired the connectors for both the speedo and GPS unit yesterday. I left the GPS harness pretty much full length so if it doesn't work by the rear view mirror I can run it to the plastic vent cover on the left fender. On a side note, are we sure it's a slow reacting speedo and not a slow accelerating Defender?
Did you program speedo to 22k pulse per mile?
Old April 20th, 2015, 05:10 PM
BlackField's Avatar
BlackField
Oscar
D110
Not yet. Its raining pretty steady here so that killed my momentum on this project.
The instructions I have say 200,000 pulses.
this is the one I have:
Old April 20th, 2015, 05:14 PM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
Not yet. Its raining pretty steady here so that killed my momentum on this project. The instructions I have say 200,000 pulses.
I left off a zero. I reconnected to constant power. Speedo seems to work pretty good. VDO tech support is awesome.
Old April 20th, 2015, 05:17 PM
BlackField's Avatar
BlackField
Oscar
D110
Speedo to constant power or the GPS unit? Did you use 220,000 or 200,000?
Im wired to constant power for GPS and IGN 12v for the speedo.
Old April 20th, 2015, 05:18 PM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
Originally Posted by blackfield View Post
so did you use 220,000 or 200,000?
200,000.
Electronic GPS Speedometer VDO richord Defender Technical Discussions 14 November 13th, 2017 12:25 PM
VDO Vision Speedometer lrnasd90 For Sale - Parts 3 May 2nd, 2013 07:27 AM
VDO Speedometer Hall Effect Sender dsh12 For Sale - Parts 3 May 8th, 2010 08:13 AM
VDO speedometer sender oldscratchggf Defender Technical Discussions 0 October 19th, 2006 08:30 PM
hella vision plus headlamps Gore Ranger For Sale - Parts 3 July 1st, 2006 06:15 PM
