VDO gauges - help - Defender Source
Old May 13th, 2012, 03:08 PM
Mrenkil
'86 D90 w/ 300tdi
VDO gauges - help
I could use some help getting the right gauges. I'm new to LR/Defender and have a 300TDI in an '86 wagon, just to add some fun to the hunt for the right items. I bought new gauges and out of 4, only the tach was the right one. The guel guage sender didn't match what is on the tank, but after looking at the fill tube and cap, I think the tank my be off of a Series. Here are two pictures I have taken. Any help on the right guages to get would be appreciated.
Need:
Speedometer
Water temp sender
Fuel guage / Sender
ID:	51502   Click image for larger version
Old May 13th, 2012, 03:56 PM
Need:
Speedometer
Water temp sender
Fuel guage / Sender
Measure the resistance of your fuel sender empty and full and you will know what's the matching gauge. For the temp gauge ... Buy a new matching sensor. For the speedo you probably need a VSS ( vehicle speed sensor ) to replace the cable setup.
Old May 13th, 2012, 08:41 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
There is a long thread on replacing VDO gauges here that lists all the correct parts. Do a search.
Old May 17th, 2012, 08:22 PM
Mrenkil
'86 D90 w/ 300tdi
Bump. By the pictures, does anyone know which fuel tank this is originally from. In d90 now, but I don't think it's stock.
Old May 17th, 2012, 11:38 PM
Looks like a stock 90 tank from those photos.
New VDO Vision water temp gauges TS888 For Sale - Parts 4 March 9th, 2012 01:38 PM
VDO gauges? Hammertime Defender Technical Discussions 10 July 31st, 2011 05:42 PM
VDO Gauges mgrgpg For Sale - Parts 21 October 22nd, 2008 05:28 PM
FS: VDO Gauges, Switches, Brush Bar NASD90 For Sale - Parts 4 July 4th, 2006 06:35 AM
Source for VDO gauges loykd Defender Technical Discussions 4 February 23rd, 2005 08:08 AM
