VDO Fuel Gauge moving around when driving????? - Page 2 - Defender Source
Old April 23rd, 2014, 09:11 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Did you run a separate (+) hot wire to the new gauge as required or tap off a positive lead shared by other electrical devices?
RDavisinVA
Old April 23rd, 2014, 10:12 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
I did not run a new/separate +, I followed the instructions on here which said to use the current wires. So I just replaced the connectors.
Old April 23rd, 2014, 10:42 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
It sounds like a loose connection, that's the easy answer I realize, I would heat, solder and shrink wrap everything at the gauge, go back and do the same at the sender and see if that resolves the issue. Just because everyone's gauge does it doesn't mean it should. and everyone is right about the float, it moves around a lot, there must be a way to add impedance to the current to keep it from reacting quickly to changes at the tank. If the stock gauge does it then it must have a mechanism for dampening the current. Or maybe you put your old internals in the new gauge
Old October 29th, 2015, 12:30 AM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
My original gauge on my 1997 SW was totally normal with no noticeable movement then all of a sudden its starts dancing. If I turn right, it goes all the way to the right, same thing if I go left. Its moves if I go over rough terrain. it evens back our on smooth road but its really annoying. Never quite sure the level of the tank. I replaced the fuel pump thinking it was the sender and no change.
Has anyone found a fix for this? Is it a grounding issue?
Old October 29th, 2015, 06:09 AM
Fuel sloshing around tank.
Old October 29th, 2015, 08:11 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
That will work half way...
When another device needs to draw some (+) amps off the same circuit, you gauge reading will drop. Same with the ground... It has to be direct off the bulkhead... share it and the gauge reading will drop when some other device needs to share the ground.
RDavisinVA
Old November 2nd, 2015, 10:10 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
New clue. Today when sitting at a stop light the road was slightly slanted to the right. I noticed the gauge was pulsating. Looked like a heartbeat. This is not normal behavior. Any mechanics out there ever dealt with this?
Old November 2nd, 2015, 10:22 PM
You really need to put the gauge against a known resistance. Then you need a multimeter to test the sender when stationary.
Your answer is usually self evident when you measure those quantities over some continuous period of time.
Old November 3rd, 2015, 06:52 AM
Were your indicators on?
Old January 4th, 2016, 11:24 AM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Finally got my fuel gauge fixed. After replacing the sender and fuel pump, checking the voltage on all the gauges and lines, checking and cleaning the grounds, I finally ordered a new fuel gauge and it now works perfectly. I guess the gauge had gone bad. It wasn't cheap...a genuine one was in the $300 range. But if anyone else is having a similar issue look at the gauge.
Old January 4th, 2016, 12:16 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I wonder if the simple placement of an in-line resister close to the gauge that could moderate the wiggling of the needle ?
fuel, vin
D90 Fuel pump stays on jackaaaps Defender Technical Discussions 0 January 23rd, 2014 09:46 PM
No brake lights, turn signals, temp or fuel gauge. John T Defender Technical Discussions 1 August 3rd, 2010 12:54 PM
VDO Vision Series Fuel Gauge surf110 Defender Technical Discussions 4 September 13th, 2006 04:04 PM
bouncing fuel gauge mattdh Defender Technical Discussions 18 June 13th, 2006 02:17 AM
