VDO Fuel Gauge--does it see in "real time"? - Defender Source
Old February 16th, 2015, 12:37 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I installed a VDO fuel gauge today and I was surprised at the readings. I think that it is reading the right level of gas, but any turn, brake, acceleration, ETC... shows up immediately and the gauge reflects this. I believe even sloshing in the tank is showing up. Anyone else experience this?
Old February 16th, 2015, 01:01 AM
You may have a grounding issue.
Old February 16th, 2015, 04:57 AM
Ground issue. Does the reading change when you turn on the headlights or wipers?
Old February 16th, 2015, 07:30 AM
Mine moves like this too. I assumed its normal.
Old February 16th, 2015, 08:19 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Thanks-- I'll check out the grounds.
Old February 16th, 2015, 08:28 AM
87 D110 (Ruby)
mine does the same thing when it is at about 1/4 of a tank per the gauge...I assumed this was normal - with the float
Old February 16th, 2015, 08:56 AM
Yes, stock did this as well
Old February 16th, 2015, 09:22 AM
The stock gauge gas more dampening of the signal so you do not notice it as much.
Old February 19th, 2015, 07:30 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
My stock gauge has dampening, but you still see it in hard turns, etc.
Old February 19th, 2015, 08:49 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Mine does this as well. It will swing wildly when I turn but will return to normal relatively quickly. I figured it was normal operation.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old April 20th, 2016, 11:39 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
First time D90 owner.. and after fueling up for 1st time, I noticed the fuel gauge needle "sways" slightly (between full and 3/4 part of gauge) when car turns/accel/brakes.
It sounds like the swaying is normal, and the behavior is likely from the sender unit and not the gauge(s). I was thinking of replacing factory gauges with VDO... but VDO gauges would not solve that. Correct? Thanks!
Old April 20th, 2016, 11:58 AM
Just enjoy some of the many quirks of owning a defender before going and trying to change them all at once your first week of ownership.
Old April 20th, 2016, 12:45 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Seriously, I reset my Odometer with every fill up and figure out approximate mileage/tank just go keep me sane.
Old April 20th, 2016, 02:59 PM
Rommel's Avatar
Rommel
Rolf
94/95/97 Many
fuel gauge
The tank gauge is only to remind you to set the trip odometer,the odometer is there to remind you to be wearing comfortable shoes at about 200 miles
rolfsauto.com
Old April 20th, 2016, 03:07 PM
jperakis
James Perakis
94 ST
lol ain't that the truth.
Years ago in my first 94 ST (#444 which I miss dearly), I drove from OC (LA) to SD downtown many times a week ... roughly 200 miles per trip
Those years when gas crept up towards $5/gallon were super fun
remember two things...
Old April 20th, 2016, 06:35 PM
lithium1330
'97 SW NAS 4.6
Lol. Thanks for the humorous reality check.
As a German car owner, new to Defenders, I need to look at my D90 relationship very differently.
Btw, I assume the having to slam the door twice before it shuts it's also the norm?
Old April 20th, 2016, 06:45 PM
My gauges are very accurate. Doors can be adjusted.
Old April 20th, 2016, 09:08 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Check the door strike on the frame. On the round horizontal part there is a clear plastic around a portion of it. It wears out, it's to keep down the metal to metal contact & subsequent rattling. If the plastic is no longer tight on the round horizontal post, it will make the door hard to fully latch on the first slam shut
Old April 20th, 2016, 09:47 PM
If you get real low, don't take right turns fast.....fuel starvation happens quickly....
Old April 26th, 2016, 01:11 PM
rankar's Avatar
rankar
Sage advice Josh.
Sent from my LG-H900 using Tapatalk
fuel
VDO Fuel Gauge moving around when driving????? bradfordish Defender Technical Discussions 30 January 4th, 2016 12:16 PM
VDO Gauge Swap "master list" kinetic Defender Technical Discussions 41 February 20th, 2015 08:33 PM
My importing a 1983 Land Rover 110 story in real time evilfij Smaller Projects 104 July 8th, 2010 11:06 AM
VDO Vision Series Fuel Gauge surf110 Defender Technical Discussions 4 September 13th, 2006 04:04 PM
