Various Wheel Offsets - Defender Source
Old June 28th, 2009, 03:23 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I have not had to measure offset before so I may be off by a bit but do these figures sound correct?
Stock tubed steel rims (centre riveted to rim) (1992) +35mm
NATO tubeless steel +25mm
Zu Alloy +11mm
5 Spoke Challenger (15in they claim 16in coming)
If I am reading things correctly then the NATO get you 1" of increased track width and the Zu Alloy 2" without using spacers, can anyone comment on how much each would improve turning circle if the same size tires were used?
I have a set of Zu coming for the 110, but I was thinking of widening and offsetting the stock tubed ones for use with Simex tubed Centipedes, are they a reasonable choice for that?
Old June 28th, 2009, 11:06 PM
Are your stocked tube wheels 6.5in or 5.5in?
Old June 28th, 2009, 11:10 PM
ajh
Andrew J. Hutton
They are 6.5".
Old June 28th, 2009, 11:12 PM
I don't see why it would not work then, but why widen and not just recenter for more offset?
Ron
fs, wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
