Vapor locked...what to check? - Defender Source
Old June 27th, 2011, 10:55 AM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
'95 D-90: While driving out to Moab, started stalling 3 times at hwy speeds, black smoke, cleared up 30-40 seconds; felt like it was fuel related; while running Hell's Revenge, same thing...thought is was MAS, swapped in a spare, no change, maybe fuel pump going or ground short so started checking for loose wires and noticed slight fuel drip @ fuel evaporative canister line fitting...removed gas cap to relieve pressure...fired right up. Happened again, loosened cap, ran great...same on return trip home...check engine light came on (oops; ran engine while removing gas cap entirely), have not read the code...note that this same symptom happened a couple of times wheeling last summer @ timberline but cleared up quickly...
any ideas? Bad cap, evaporative canister relief ? other?
thanks,
Old June 27th, 2011, 03:41 PM
Naplm00
Matthew
sounds like a plugged fuel filler cap to me.. can you hear pressure whooshing noise when taking off the gas cap?
Old June 27th, 2011, 04:26 PM
Me too. Other issue could be the exhaust leaking cooking the fuel in the tank.
Old June 27th, 2011, 05:16 PM
PMKColorado
Paul Koentges
no exhaust leak...new from cats back with magnaflow; When removing gas cap, pressure is releived...
Old June 27th, 2011, 05:31 PM
cap first, then check that the lines are not plugged or crushed.
Old June 27th, 2011, 06:20 PM
LRover's Avatar
LRover
J. Michael McCaig
Also check the vacuum line that goes to the fuel pressure regulator behind the intake.
Old July 3rd, 2011, 11:51 PM
PMKColorado
Paul Koentges
fuel pressure regulator-sticking
regulator is sticking...a few sharp taps and it runs great. symptoms are stalling, starving for fuel, vapor lock, and gas smell out back...can it be cleaned/serviced?
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
