Vaper or Smoke around Gas Cap - Defender Source
Old October 5th, 2015, 11:23 AM
RBlood
Rob Blood
2005 LR3
So, I have just taken delivery of my 1985 90 so am very excited. I'm wondering if it is typical with a 200TDI to have some vapor or smoke coming out around the gas cap area. There is also a small tube just beneath the gas tank that seems to emit exhaust or vapor. See the attached video for visuals.
Old October 5th, 2015, 12:37 PM
I'm assuming that the vapor is either atomized diesel (which makes no sense to me) or crank case smoke (also not right to me) and that small line at the bottom of the tank you are referring to is the tank vent. you have the diesel pickup, the leakback, the vent and the fill. pickup and leakback are a closed circuit. Neither are exposed any kind of crankcase pressure that would pressurize your tank. if you're engine is idling and you remove the fuel cap, do you get vapor coming straight out of the fill?
Just to clarify, when you say gas cap, do you actually mean gas/fuel cap in the back, or oil fill cap?
Mark Kellgren
KM4BOR
gas, gas cap
gas guage bouncing around CDeWan Defender Technical Discussions 8 April 18th, 2012 12:21 PM
Gas Cap leak Doug Defender Technical Discussions 7 April 22nd, 2005 01:03 PM
Gas Cap!!! Dfndr90 Defender Technical Discussions 14 August 26th, 2004 09:14 AM
Need replacement locking gas cap vnrover Defender Technical Discussions 17 April 10th, 2004 04:29 PM
