Vacuum pump TDI300 - Defender Source
Old June 4th, 2005, 05:18 PM
gali
Gali k
Vacuum pump TDI300
The patient is a 97 TDI300 SW, it's quite a time he suffers from a poor braking ability.
Well, I suspected the vacuum pump mounted on the engine, since it leeks a bit (like most stuff on land rovers ).
First thing I gonna check the vacuum it gives, but I donít know which values it should give normally.
So my first question is what are values it should give Vs. RPM?
Next, since the bitch is a my daily vehicle I didnít had a chance to take a god look at the vacuum pump Ė mounted bellow the air filter cartridge. So, anyone has a clear shot of the pump?
I'm almost sure the problem is not the booster, since the brake pedal doesnít go all the way to the firewall.
If the vacuum rate will be normal, or maybe anyway, I'll replace the one way flow valve.
Anyway thanks for all answers to come
Gali.
Old June 5th, 2005, 12:11 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I am sorry I do not have any answers for you, but it is very cool that we have a member from Israel. I work for Hanita here in Cali. Over here we love Israel. Keep up the good fight, good luck with the brake problem.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
ac, tdi, vacuum
300tdi vacuum pump D90user Defender Technical Discussions 22 April 21st, 2009 04:39 PM
