Vacuum Leak - Defender Source
Old November 25th, 2004, 04:05 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Vacuum Leak
Was at the stealership to hook up to the test book.
"Test book system. Codes for 02 sensors up and downstream open cicuit. Vacuum leak at intake."
Suggested changing the intake manifold gasket. Vacuum leak was throwing off 02 sensors.
Is this the valley gasket under the intake trumpets?
Any other gaskets involved? Plenum chamber looks like it has haylomar sealant.
Looks like a straight forward job that can be done in a weekend. Anything to look forward to?
Just don't feel like paying 5+ hours at 125 a pop to get this done for a $20 dollar gasket.
TIA,
EwS
Old November 25th, 2004, 05:23 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
With the engine running, spray carb cleaner strategically around the engine compartment to find the vaccum leak--when you find it, the engine rpm will go up as it draws the carb cleaner into the engine--this will identify where the leak is as it might be a hose in lieu of the gasket. The valley gasket is slightly more involved of a change, but totally doable. the intake plenum is indeed sealed with hylomar. But again, first detect where the leak is coming from and pay careful attention to all the vaccum hoses (such as those to the brake servo and all those running into the front of the plenum). Although not unheard of having a gasket leak, it is usually a hose.
Old November 25th, 2004, 09:11 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Chris,
Sounds much more plausible as the codes from fourfold say nothing about intake itself. Not to rule it out, I'll check the hoses first. This is the same dealership that told me my heads needed to be done...
Hopefully it won't snow anymore tommorrow...
EwS
Code 28 - Air leak
check for air leaks in the following areas:
Hose, air flow meter to plenum
Breather system hoses to plenum
Brake servo hose
Vacuum reservoir hose (fresh air solenoid)
Distributor vacuum advance
Hose, purge valce to plenum
Injector seals
Joint - bypass air valve to plenum plenum chamber to ram housing ram housing to inlet manifold inlet manifold to cylinder head bypass air valve hose
ac, vacuum
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
Vacuum pump TDI300 gali Defender Technical Discussions 1 June 5th, 2005 12:11 AM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
