Vacuum Advance - Defender Source
Old April 24th, 2007, 09:01 AM
Andrew Vick
Andrew Vick
95 D90
Vacuum Advance
My vacuum advance is barely hanging onto the distributor. The screw that you can get to on the front will not tighten, and I'm wondering if theres a tiny nut on the inside or how it attaches. Thanks for the help.
Old April 24th, 2007, 11:44 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
There is a threaded insert in the distributor. Thread size is M3.5x.6
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old April 24th, 2007, 01:52 PM
Andrew Vick
Andrew Vick
95 D90
Thanks Rob. So assuming that threaded insert is gone, can I use a tapping screw for now, or is it new distributor time?
Old April 24th, 2007, 08:40 PM
Andrew Vick
Andrew Vick
95 D90
It seems that the screw would be under the flash cover where the mechanical advance is. If a new screw protruded into that space a bit, would it cause problems?
Old April 24th, 2007, 11:28 PM
pendy's Avatar
pendy
jim pendleton
89'd90
No there is room behind the body of the distributor for a longer screw.
JP
legend in my own mind
Old April 25th, 2007, 06:08 AM
Andrew Vick
Andrew Vick
95 D90
Perfect. Thanks JP.
Old April 25th, 2007, 09:58 PM
pendy's Avatar
pendy
jim pendleton
89'd90
loctite is your friend
Old April 26th, 2007, 07:49 AM
Andrew Vick
Andrew Vick
95 D90
The threaded insert that Rob referred to is worn out and won't stay put. Loctite it is. Thanks for the ideas.
Old April 26th, 2007, 04:34 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Loctite isn't glue, it just keeps screws/bolts from backing out on their own. If the insert is loose you need to find a fix other than just slapping loctite on it.
Old April 26th, 2007, 04:50 PM
Andrew Vick
Andrew Vick
95 D90
Understood. Poorly worded on my part.
Old April 26th, 2007, 09:51 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Take it apart and put a nut on the inside.
JP
Old April 27th, 2007, 08:25 AM
Andrew Vick
Andrew Vick
95 D90
That's the plan. Funny thing is, it runs just fine.
Until water or some such crap gets in there
ac, vacuum
Vacuum Advance revtor Wanted 2 June 2nd, 2008 11:24 AM
Vacuum Advance CGunther Defender Technical Discussions 0 September 28th, 2006 12:52 PM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
Vacuum pump TDI300 gali Defender Technical Discussions 1 June 5th, 2005 12:11 AM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
