V8i air filter mounting? - Defender Source
Old May 26th, 2009, 07:57 AM
ajc219
Andrew Cleland
1993 Defender 110 V8i
Hello,
I've a Defender 110, started out as a 2.5L petrol and then got converted to a 3.9i V8. When I bought it the air flow meter was bolted to a wing with a short hose to the plenum and no air filter. After a lot of messing around trying to get something to fit I gave in and bought a genuine air filter and hose for a V8i Defender - the filter is the round drum with a snout that fits near the bulkhead (firewall) with the air flow meter clipped to it and the hose then loops through 180degrees round to the plenum.
Stupidly I thought fitting it would be obvious but it isn't - I was wondering if anyone with a genuine V8i Defender could give me a clue or two how the filter is fitted - ideally a photo would be good!
Cheers,
AndyC.
P.S. I'm in Cambridge, UK, so V8i Defenders are a bit hard to find.
mount, v8
New Air filter box for HS 2.8 engine Santiago Defender Technical Discussions 6 November 17th, 2016 04:33 AM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
air filter box mattdh Wanted 1 September 14th, 2005 12:42 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
