V8 Won't start - Defender Source
Old October 27th, 2013, 05:58 PM
Nate6472/
Nate
88 D90 V8
V8 Won't start
replaced the ignition switch and the alternator. Went to start and it started and ran for 10 seconds, then dies. Has to sit for awhile before it will do it again. Fuel is getting the the SUs and I blew out the lines between the tank and filter and filter and SUs. Any suggestions appreciated.
Old October 27th, 2013, 06:20 PM
I'd test fuel pressure. Wondering if pump is borderline
Old October 27th, 2013, 06:25 PM
Nate6472/
Nate
88 D90 V8
Not sure how to do that. Does the fuel pump in the tank produce this? When I disconnected the fuel line at the carbs, the stream was steady and full.
Old October 27th, 2013, 06:56 PM
Fuel filter ... assuming that the pump has to be working or it wouldn't start at all ...
Old October 27th, 2013, 07:23 PM
Nate6472/
Nate
88 D90 V8
Filter is an easy next step. Not sure of history of the filter any way. When I diconnected the hose coming from the tank and hit the key, fuel flowed freely but the same happened when I disconnected at the carb with the filter in place. Someone in the UK suggested a jet is clogged.
start, v8
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
