V8 Rebuild - Page 2 - Defender Source
Old August 13th, 2015, 08:33 AM
ezzzzzzz
Mark Garrenton
anything worth doing is worthy of over doing Mark ?
3/4 impact LOL,
Yep! It beats the crap outta pulling shoulder muscles yanking a breaker bar. Thump, thump, thump and those bolts are free spinning.
Old August 13th, 2015, 09:15 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I agree with Bill. I've rebuilt many rover motors and my 4.6 In the Defender I used ARP Studs. Been perfect, 80k miles later.
I also agree with pressure testing block. I've had both slipped liner and porous block. A slipped liner could be difficult to see if it was stopped while in position. Head gasket has some signs at times.
If you can't find anything obvious that caused pressure leak and vibration, I'd consider complete tear down and check up. It's out of the truck... Now is the time.
If it were me, I'd consider top hating the liners if it doesn't pass pressure test. I personally wouldn't consider using another used rover block that hasn't been pressure tested. Ever.
Old August 13th, 2015, 10:11 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by Abrooks View Post
I'll give that a try, thanks.
Oh, and as recently as 2 days ago I was exchanging emails with Will on getting both new and used parts, so I believe he's still in the game.
That's good to hear--- I havent spoken with him in a few months(which is a long time for me!)
He's had a lot of other stuff going on but maybe he's going to keep a foot in the door.
Rent my
Old August 14th, 2015, 08:43 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
That's good to hear--- I havent spoken with him in a few months(which is a long time for me!) He's had a lot of other stuff going on but maybe he's going to keep a foot in the door. .
I hope he does. The last MAR when he show in a Gwagon hurt a little. I want to see that hippie in D1 again.
Old August 14th, 2015, 04:56 PM
Abrooks's Avatar
Abrooks
Tony Brooks
So all but one head bolt off on the DS. Found that one is hidden under the alternator bracket. Is this normal?
yup.the original setup that bolt had a stud off the top of it and a nut to hold the bracket down.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old August 14th, 2015, 05:13 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks, Dave.
For the record, some taps from a ball peen hammer per Crowther and a short 5/16 on a 2' cheater with a hi lift handle worked well.
Old August 15th, 2015, 03:43 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Got the heads off (which necessitates removing the distrubutor, PS bump, AC compressor and brackets, etc). Despite the grunge, everything seems OK in that nothing stands out as being amiss. Both head gaskets look intact and the only variance amongst the pistons is that #4 (which had a normal compression reading) was slightly cleaner than the others. I suspect that it could be due to the fact that the center lower head bolt was only slightly more than finger tight.
Off to the machine shop Monday!
Old August 16th, 2015, 07:35 AM
1of40's Avatar
1of40
1of40
Which machine shop are you headed to?
Old August 16th, 2015, 07:37 AM
Abrooks's Avatar
Abrooks
Tony Brooks
J&F on four mile run in Arlington.
Any thoughts on replace or cleaning rocker arms?
Old August 16th, 2015, 08:36 AM
Ray_G's Avatar
Ray_G
Ray Gerber
All great automotive feats can be solved on 4 mile run, the closer you get to Weenie Beenie the better!
Old August 18th, 2015, 07:11 AM
Abrooks's Avatar
Abrooks
Tony Brooks
#8 con rod looks straight, can't see any obvious wierdness now that I have the bottom end exposed. Next is to see what the shop says.
Old August 18th, 2015, 08:18 AM
ezzzzzzz
Mark Garrenton
I'd pull it to have the assembly checked and view the bearings too. Those damn rod bolts are known to gall when removing them. Just crack both slightly loose and remove a bit at a time on either side, by hand, to hopefully avoid issues. Stupid old Buick engine design. After all these years a better mouse trap should have been implemented.
Old August 18th, 2015, 08:39 AM
Abrooks's Avatar
Abrooks
Tony Brooks
With 110K estimated on the motor (3K on cam and lifters), is a complete tear down really necessary? I'll chat with the shop, but at some point I need to say "when".
Old August 18th, 2015, 11:32 PM
I would want the block at least to be pressure tested at running temp.
Present:
1987 RRC- "Chewy 2"
Past:
Old August 19th, 2015, 05:10 PM
The Dro
Dro
1988 Ninety
Pete is a great guy to deal with...
J and F Motors
4064 S Four Mile Run Dr
Arlington, VA 22206
Old August 19th, 2015, 05:33 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Pete is working on the heads now. He and I had a long chat today about 4.6 blocks.
Old August 19th, 2015, 08:33 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
You have to share what you learnt!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 21st, 2015, 04:49 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I've gone ahead and dropped off the intake manifold, rocker assemblies and valve covers to get dipped. Valve stem seals should arrive early next week so with any luck reassembly can begin next weekend.
Old August 26th, 2015, 12:38 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Dropped off the valve stem seals today, heads and intake have been dipped and blasted, heads need to be lightly milled but pressure tested fine. Valves will be lapped tomorrow.
rebuild, v8
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
nice 110 rebuild on ebay Campbell Misc. Chit-Chat 6 July 14th, 2004 07:28 AM
where to find rebuild manual for 4.0L? Chris Cox Defender Technical Discussions 0 January 27th, 2004 09:36 PM
tranny rebuild mattdh Defender Technical Discussions 15 November 12th, 2003 01:09 PM
