V8 r380 can it... - Defender Source
Old November 26th, 2010, 01:30 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
V8 r380 can it...
Can I use a r380 from a NAS v8 D1 with the Disco 200Tdi in my 110? I know about the fitment, just need to know if the gearing in the r380 is correct for the 200Tdi. Just one of many questions coming...
Old November 26th, 2010, 09:40 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Gearing is different, input shaft is different. What you need is the short shaft r380 setup for diesel. http://www.ashcroft-transmissions.co...&productId=157 This is the replacement for the diesel lt-77. I've been told by ashcroft that shipping would be around 200.
Old November 27th, 2010, 05:34 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
http://members.shaw.ca/red90/gears.html It appears only first/fifth gear are slightly different between the V8 vs. TDI R380. I myself have wondered if it would be possible to swap the input shaft/bellhousing from a TDI R380 into the NAS V8 R380. The gear selector will be farther back on the v8 r380 and could possibly require you to modify the seatbox to make room for the gear select. Anyone have any more information regarding this?
Old November 27th, 2010, 06:43 AM
I know a guy who put a v8 r380 behind a 2.8 TGV - it fits and runs fine with the correct length bellhousing (modified v8 one? I don't know. Clutch is on opposite sides. In the end he was really pissed off since he then had to change the position of the trans/t-case mounts and had to make custom length driveshafts.
------ Follow up post added November 27th, 2010 12:45 PM ------
Oh, and the only reason that the input shaft fit into the pilot bushing is that he had a custom one made.
Old November 27th, 2010, 11:33 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
When it comes to transmissions, buy the new one. It's worth it. No sense having to deal with someone else's worn syncros etc. I got mine 2nd hand because it was before Ashcroft started doing the short-bellhousing again, but today I'd go new without thinking twice.
Old November 27th, 2010, 12:18 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Know about the fitment issues...was looking for gearing info, Then found the link on Ashcrofts website...
thanks
Old November 27th, 2010, 12:21 PM
Yes. I just unloaded a short input shaft and short r380 bell housing from the container on Wed. for someone else doing the exact same thing.
Frank if you want this stuff contact Dave Ashcroft and then shoot me an email. Have a container leaving again this coming week.
Old November 27th, 2010, 12:26 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Thanks Doug..changed the transmission fluid and 3rd gear is back.I may just rebuild the lt77. It's running great and I really can't find any MAJOR rust issues...
Old November 27th, 2010, 12:50 PM
based on the cactus in your drive ways shots I'm guessing it may never rust now.
there has to be something that can be done to tighten up the shift gates and rattle in the lever
Old November 27th, 2010, 01:06 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I don't think rust will be an issue now...I'm with ya on tighten the shift gates
Old November 27th, 2010, 03:04 PM
ajh
Andrew J. Hutton
On a somewhat related note, the almost new (6000mi) clutch release bearing is squeaking now, is there any in-situ treatment that can help quiet it down, I don't really fancy pulling the entire transmission... again.
r380, v8
WTD: Good R380 for V8 owen Wanted 1 November 3rd, 2010 09:06 PM
Difference between TDi R380 and V8 R380? turbodave Defender Technical Discussions 5 July 19th, 2008 06:15 AM
3.9 engine, R380 transmission Shane@EVS For Sale - Parts 7 August 3rd, 2006 04:04 PM
r380 diesel/v8 question D90user Defender Technical Discussions 5 January 1st, 2006 07:15 PM
R380 source opinions D90user Defender Technical Discussions 12 December 8th, 2005 12:22 PM
