V8 Push rod question - Defender Source
Old June 25th, 2016, 11:32 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Putting my motor back together today and had a question.
Does it matter which way the push rods go in. We can't recall how we took them out.
It does not appear that it matters as both the rocker and the lifter appear to be the same but just wanted to make sure.
Thanks!
Old June 25th, 2016, 12:26 PM
Ideally they should go back where they started. I would just reinstall since that is your only option. Make sure none are bent.
Old June 25th, 2016, 02:03 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
We know which cylinder they are for just did not mark orientation.
Yes none are bent all is good there.
Old June 25th, 2016, 07:01 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
I don't know about Rovers, but in GMs the wear mark is a bit different between lifter and rocker sides.
Sent from my SM-G920F using Tapatalk
I'm for the Russian pencil
Old June 25th, 2016, 07:38 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
The only two times I did this job, I poked them all through a shoebox lid.
Kept them all in order and top/bottom.
I'd guess if you can't see a difference in wear then it ain't gonna matter.
Rent my
Old June 25th, 2016, 08:55 PM
i think it mattersm i dont have a way of telling the difference i lable my push rods when i remove them Dr. Bang always has a new pair of Vans so i imagine he doesnt run out of storage
Old June 25th, 2016, 10:19 PM
It doesn't matter. Think of all of the head gasket jobs that have been done on Rover V8's over the years, and how many had the push rods put back in the correct spots. It would be well documented if it was a real concern.
Old June 25th, 2016, 10:45 PM
Originally Posted by Omero View Post
I don't know about Rovers, but in GMs the wear mark is a bit different between lifter and rocker sides. Sent from my SM-G920F using Tapatalk
Just so you know, the Rover V8 was a GM V8 until bought by Rover.
Old June 25th, 2016, 11:18 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Cool. Thanks for the help. That is what I assumed but just wanted to make sure.
Almost back together just a little more tomorrow and hopefully all is good.
v8
Who is a clutch push rod expert? o2batsea Defender Technical Discussions 5 January 11th, 2013 04:27 AM
1998 range rover convertible one-of-a-kind 4x4 sut like hot rod street rod Capt Milks The Flea Market 0 December 2nd, 2011 07:06 AM
Series 3 clutch push rod too short ? kjva Series Technical Discussions 2 May 17th, 2011 08:40 PM
Equipe Panhard Rod and HD Track Rod Rugbier For Sale - Parts 14 March 23rd, 2011 09:27 PM
Tie Rod/Track Rod joint removal....aarrrrghh DNinety Defender Technical Discussions 5 October 24th, 2010 01:08 PM
