V8 major tune up - Page 3 - Defender Source
Old April 7th, 2013, 09:49 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Finally putting this engine together, it's going smooth so far, fingers crossed.
My exhaust manifolds hardware is in very poor condition, can you use stainless there ?
I was thinking about skipping spacers and use allen SS with spring washer and anti seize compound ?
Any reason why I should not do this ?
Cheers
- Charles Eames
Old April 8th, 2013, 06:21 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
I would shy away from
Using stainless ....bolts are weak and increased chance of corrosion....a quality grade 8 with anti seize and lock washer would be fine
No Mall crawler here
Old April 8th, 2013, 12:03 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Anyone has an explanation on function of the exhaust bolt spacers on the 4.6 ?
My 2c is that they will give more space around head of the bolt, easier removal and installation, but I've heard that they act as springs () and also that they allow better torquing ?
- Charles Eames
Old September 12th, 2013, 03:51 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
idle dropping
Finally finished this, took some time but the result is neat.
Engine started fine, just after very few cranks, it's reving very well, you can feel the torque, but after it get to normal operation temperature it won't hold a stable idle, it will drop and sometimes die.
I will check IACV and vacuum line tomorrow, any other ideas or suggestions ?
Cheers
- Charles Eames
Old October 31st, 2013, 07:49 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Found the issue, bad MAF sensor, voltage not rising with RPM. Put a new genuine Bosch MAF sensor and it's all fine, nice and quiet idle, no drop and no stall.
Cheers
- Charles Eames
v8
1965 V8 Series 2a RoverLover5023 For Sale - Vehicles 0 August 7th, 2012 10:37 PM
3.9L V8 Longevity Holiday Defender Technical Discussions 7 May 18th, 2011 04:29 PM
3.5 V8 vs 200 Tdi bbdesoleil Defender Technical Discussions 15 August 29th, 2010 10:17 AM
3.5 V8 Timing Chain Renewal MUDSUX Defender Technical Discussions 15 December 11th, 2009 05:21 PM
LT77 and V8 Stork17 Defender Technical Discussions 4 November 7th, 2008 03:15 PM
