V8 Engine Oil - Synthetic vs Semi Synthetic - Page 4 - Defender Source
View Poll Results: What type of engine oil do you use?
Synthetic 37 50.00%
Semi-synthetic 8 10.81%
Mineral 24 32.43%
Whatever I can find... 5 6.76%
Voters: 74. You may not vote on this poll
Old January 19th, 2013, 05:18 PM
Valvoline VR-1 or Amsoil 10w40, my engine builder says 1200 ppm Zinc for flat tappet cams.
Old January 20th, 2013, 01:55 AM
CDeWan
Clay DeWan
5.3L beastie
blah blah. PO of my truck ran high end synthetic and got 266K on the ticker. I continued this until my dumbass overheated the motor. So all that the money spent on the hight end oil..flush..right down the drain as I had to rebuild it anyway. Why waste the money on synthetics is now my philosophy so I run a good convention oil and just change it. You can pick it up anywhere and the V8s are not overly hard to rebuild. just my 2 cents.
Old January 20th, 2013, 05:02 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Frequent oil changes were my preferred route, I used to add flushing additive before changing the oil too. Mineral oil changed every 4000 miles.
Now days I use semi synthetic in my 200tdi, add flushing additive every time I drop the oil and use flushing oil every other oil change. The oil stays clean for about 1000 miles after the change. I change the oil every 5000 miles. Current milage 232000 miles.
Mike Hammond
Old January 20th, 2013, 05:18 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'93 NAS110 #436
I'm with you. Dino oil has worked fine since the dawn of the internal combustion engine. The vast majority of people using synthetics wont own their car long enough to see the barely perceptible results at the end of the car's life, and those motors at 150k+ miles will need a rebuild anyway if it's a restoration candidate. Save your money for fuzzy dice or twizzlers.
Semper Fi!
Old January 21st, 2013, 12:58 PM
Eric_S
Eric
'97 D-90 ST #1507
Diesel oil ZDDP levels are also dropping. Older internet post regarding diesel oil being better suited for flat tappet engines are referring to the older CI-4 and CI-4 plus rated oils, not the newer CJ-4 rated diesel oils. While diesel, oil generally speaking, does have more ZDDP, many engine builders believe it is not enough for flat tappet engines.
The Rover and the ’68 Olds both get Valvoline VR-1 10W-30, 1400ppm zinc and 1300ppm phosphorus (also available in 20W-50). Any Napa will be able to get if for you, usually next day. I also run Napa gold filters so it makes for one stop shopping.
Here’s a link to ZDDP levels of Mobile One oils. I’m not sure if the information is current so “caveat emptor”.
http://www.mobiloil.com/USA-English/...c_Lifters.aspx
Old September 18th, 2016, 06:41 AM
Anschluss
T B
white 1997 Defender 90 NAS
Amsoil 10W40 with zinc plus Fram synthetic oil filter from Walmart. Every 5000 kilometers. Probably over the top but it's the way I roll. 142000 thousand kilometers thus far and no oil burning.
Old September 18th, 2016, 08:23 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
202k on a Chevy suburban $19.99 oil/filter changes at a small local shop nearest me every 5K. They rotate tires, top fluids and grease joints and shafts. Oil pressure still measure in the low 40's.
The Rovers, NAS90/ROW110, get Rotella 15-40. Watch Home Depot they sell 5qts for 10.99 most the time.
Old September 18th, 2016, 08:27 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
What does the local LR dealer charge for the same, $600?
Old September 18th, 2016, 08:38 AM
1of40's Avatar
1of40
1of40
They'd be pissed if they had to do my Rover's 5k service. To wet and dirty under there. The new rigs probably don't leak.
engine, v8
Engine Oil Pouring from engine dfscott Defender Technical Discussions 46 June 18th, 2007 08:45 AM
The Great Chicago Oil Slick.... Eric Siepmann Misc. Chit-Chat 30 October 28th, 2005 07:02 AM
Engine Oil Leak Question ronward Defender Technical Discussions 0 March 22nd, 2005 08:38 AM
Oil Info XD90 Defender Technical Discussions 5 September 7th, 2004 09:07 PM
engine oil chart from owners manual Eric_S Defender Technical Discussions 3 November 21st, 2003 09:40 AM
