V8 Engine Oil - Synthetic vs Semi Synthetic - Page 3 - Defender Source
View Poll Results: What type of engine oil do you use?
Synthetic 37 50.00%
Semi-synthetic 8 10.81%
Mineral 24 32.43%
Whatever I can find... 5 6.76%
Voters: 74. You may not vote on this poll
Old January 18th, 2012, 01:59 PM
Makes sense they are still heavy as your engine seemed to have a lot of gunk.
Old January 18th, 2012, 03:42 PM
RANGEROVERSURFER's Avatar
RANGEROVERSURFER
Tony
95/Range Rover Classic
Alaskan RR/Classic SWB 3.9 Rotella Trip T Experience
Hello, I just wanted to add my own experience with running Rotella Dino Triple T White Jug versus Rotella Synthetic Blue Jug. I have been running Rotella Dino for 2 years and I immediatly noticed an increase in compression, I live on the side of a mountain , here in Anchorage. We often get below zero in the winter, so I wanted to try the Synthetic. well I did, immediately I noticed a huge loss in Engine Power, the motor was louder, valvetrain noise etc. overall I changed back within 2 days. I park outside and have a block heater, battery blanket in addtion to an Oil Pan heater. i let the Rig warm up for about 20 min in the morning and off I go. I have approx 125,000 miles on the Motor and notice that the Oil is black by the time I go to change it at 2500 miles or so. I had the Oil analyzed at Blackstone labs and they gave it a major thumbs up! I am thinking that the High detergent and the fact that it has ZDDP as well as being an Old Style motor and that Rover V-8's run dirty to begin with. I respect that every body has their opinion of what works for them as such. Could My Rover use new Valve Cover Gaskets, yes, does it need new Exhaust manifold gaskets, yes,but I tighten them down every so often. My Rig is lifted, running 265/75/16 BFG's , with Flowmaster Exhaust and it runs really smooth when I ran the Rotella Synthetic the engine was so low on power and noisy, I was getting really concerned. So the 15W40 works really well for me year round...Thanks for allowing me to reply, disregard the Shell Sticker, I don't work for them.
Tony
Name:	Hope Alaska Sept 2010 021.jpg
Old January 18th, 2012, 03:50 PM
Tony:
Nice post, thanks for passing it along. So you're not adding any ZDDP to the Rotella white jug, correct? Just the inherent ZDDP that is in the oil itself?
Old January 18th, 2012, 03:58 PM
RANGEROVERSURFER
Tony
No addtl ZDDP added
No I am not adding any additional ZDDP. I actually have 2 RR Classics and run Rotella Triple T in both of them. I see the advantages and researched and came across the -25 below F Pour rating etc. overall the driving that I do, and the Alaska climate as well as climbing a Mountain year round, I will not change over. to be honest the only downside is that the 02 Sensors or Cats may not last for ever, but way cheaper than an engine rebuild. Just my 2 cents.
Tony
Old January 18th, 2012, 04:11 PM
Cool...I likewise already run Rotella in every "older" car I have...but likewise don't add ZDDP so was curious if your tests were with or without an additive. But I'm a Rotella 15W40 fan already...
Old January 18th, 2012, 04:15 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Backing Tony on the Rotella T White Jug. Oil pressue is slightly higher now and more consistent between warm up and operating temp. My only complaint is that I cant find it in QTS. So I have to do 4 oil changes before I only have to buy 1 Jug. That is ~ 2 years for me.
Old January 18th, 2012, 05:13 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Tony, thanks for sharing your experience. What do you mean by the phrase above?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old January 18th, 2012, 05:17 PM
Tony
Ps - any idea of the actual ZDDP count in Rotella? Did the tests you had done state this?
Old January 18th, 2012, 06:41 PM
RANGEROVERSURFER
Tony
Good Point / retest in order Oil Analysis
You bring up a very good point, Thanks I will have both Rigs Oil retested in the future sometime and have a complete analysis of the Oil specifically requesting the Oil be tested for ZDDP content. I was going to order the additive from British Pacific Ltd in CA, they carry some, made by Redline. I am actually doing a restoration on the 1990 SWB RR Classic Eastnor Green. I will be posting a Thread on the LRR Forum soon. They test for various metals , etc. I will find the Analysis results and post the numbers, maybe it will help.
Tony
Old January 18th, 2012, 06:56 PM
I've heard that the current ZDDP for Rotella is in the 1100ppm range, down from the 1400-1500ppm it used to be. But would be curious to know for sure.
Old January 18th, 2012, 08:02 PM
I think its even less due to the new clean diesel technology. I talked to a guy that works for a rental company and he was told by manufacturers. Not to use CJ4 rated oils in hydraulic systems. They previously used rotella.
Old February 5th, 2012, 01:29 AM
RANGEROVERSURFER
Tony
Oil Analysis Update
I located the Oil Report. Zinc is showing at 853 PPM / Phosphorus 823 PPM / Boron 37 PPM / Calcium 1953. At some point in the future I will start using a Zinc additive and have the Oil sample tested to confirm the Higher ZDDP Content. But at this Point I am still very satisfied with Rotella White Triple T and will continue using it. next year I will have the Engine Rebuilt and will share my findings with D-90. It will be interesting to see if there is an excessive amount of sludge build-up and wear.
Tony
Name:	Summer 2011 106.jpg
Old January 19th, 2013, 08:45 AM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Originally Posted by evilfij View Post
Say what you will about dino oil being better, but you could eat off the inside of my LWB which has 190k and has been run on full synthetic since ~30k.
Which brand and viscosity synthetic do you use in your D90?
Old January 19th, 2013, 12:00 PM
If you want the best AMSOIL 10w40.
Old January 19th, 2013, 12:22 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Rotella Triple T 15-40, been using this in my 96 D1 for seven years and the insides of the rocker covers are cleaner than when I got it.
Also my 200tdi 90 runs with it in.
tractorsupply $60 for 5g
Dont need no zinc it has it.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 19th, 2013, 12:28 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I use whatevers the cheapest to buy at Walmart since I have to change oil on 3 Defenders. Since Walmart sells Mobil1 10w-40 full synthetic in 5 quart jugs for like 26 bucks, I buy that. I don't go to costco to buy mobil1 anymore because they still sell it in quarts, Cheaper to buy in the larger bottle.
Robert Deniro
Old January 19th, 2013, 12:34 PM
Used Mobil1 on my D1's engine. While the insides may have looked good it didn't do anything to prolong the engine's life. Cruelly cut short at 155kmiles due to slipped liner.
My two DD's get semi synthetic and alls well (combined mileage 245,000 miles)
Old January 19th, 2013, 01:11 PM
Actually is doesnt and I am not going down this road.
Old January 19th, 2013, 03:52 PM
Why zinc and not moly? Doesn't moly have superior dry friction and pressure resistance characteristics
Old January 19th, 2013, 05:36 PM
REDrum's Avatar
REDrum
Niall Johnson
1970 Series IIA 88 - Sandstone
What do people use on Rover V8s for pre-change engine flush?
I've used Motul primarily and occasionally Amsoil. Motul seems to flush a bit more. Any others out there worth considering?
Toltec Coffee Team:
'99 UZJ 100 - for glamping and grocery getting
'94 FZJ80 - our Costa Rican coffee mule
'96 FZJ80 - 3XL, racked, shaved and dipped in Raptor coat
'70 Petrol SIIA 88 - a Costa Rican expat now with US citizenship!
'70 Petrol SIIA 88 - for Central America surf & coffee exploration
'56 Petrol S1 86 - a whole new kind of land rover hell...
engine, v8
Engine Oil Pouring from engine dfscott Defender Technical Discussions 46 June 18th, 2007 09:45 AM
Engine Oil Leak Question ronward Defender Technical Discussions 0 March 22nd, 2005 09:38 AM
engine oil chart from owners manual Eric_S Defender Technical Discussions 3 November 21st, 2003 10:40 AM
