V8 - 400mi range - Ideas - Defender Source
Old July 29th, 2013, 09:54 PM
Just thinking...
Stock 95' with a 3.9 V8 (gas)
current range is 160 street miles (ish) - stock tank...
so to double this i need 30+ gallons on board.
Add a long ranger right side tank + 6 gal (ish) - still 10 gal short... so Cans or something else needed...
I probably will not switch to Diesel (i would like to but it extends the budget for what i want to do and adds a "what if" to the formula that i'm trying to avoid..)
have something in mind as to what for. I need at least 200 miles, on fire roads range...
thoughts...
95' D90 - daily driver..
Old July 29th, 2013, 10:02 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
You "should" be getting at least 175 to 185 out of 14 gallons. Just add the 6 gallon side tank and like you said carry a can. It is what it is...not a long haul Overlander, but a capable one.
Old July 29th, 2013, 10:04 PM
Fuel tralier
Originally Posted by pendy
I'm here for the D's
Old July 29th, 2013, 10:05 PM
i'm at 178/tank now (at 125k miles) today - so yes in that range for starters. But off road with fuel far between i need range....buffer...
Plus front mounted series style tank
Old July 29th, 2013, 10:07 PM
http://www.defendersource.com/forum/...ad.php?t=31290
8 Gallons in here
Old July 29th, 2013, 10:25 PM
Yup, plus there are options for tanks under the passenger seat, etc. I have one - holds about the same.
http://www.defendersource.com/forum/...7&postcount=23
Put them together, plus one of Clay's tire carriers with jerry can holders, and you'll be able to drive from one side of the country to the other without a fill-up. Seems like plenty.
Old July 29th, 2013, 10:28 PM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
Yeah, the offroading really kills the range! Do you use a rack on top? You could always rig a low/wide eatra tank to mount on top - this way you could have a valve/hose attachment and gravity fill your main tank.. It would add some high weight on the vehicle, but by the time you get to your trails, you can fill your main tank and drop some weight lower...
Old July 29th, 2013, 10:39 PM
i was being conservative on the 6 gal that was the one i meant <lucky8llc> but 8+14=22/12=264 range - <ish via math on a 14 gallon tank, its more like 15..> off road that is more like 150-200 mi, range.
I was thinking - can an AEV fuel caddy be adapted maybe but they call out a 17" wheel..
Old July 30th, 2013, 06:06 AM
d110pickup
Mike Pado
'97 D90 ST #1153
Put them together, plus one of Clay's tire carriers with jerry can holders, and you'll be able to drive from one side of the county to the other without a fill-up. Seems like plenty.
Corrected that for you.
Mike Pado
I'm not saying that stupid people should die . . . but maybe we could remove the warning labels & let nature take it's course.
v8
1974 Range Rover 2 door classic w/ rebuilt 200tdi & 5 speed - Fun RRC! ZombieMotors For Sale - Vehicles 7 April 25th, 2013 06:57 PM
Famous Land Rover owners Lindy Misc. Chit-Chat 4 June 15th, 2009 08:49 PM
Land Rover family tree D901619 Defender Technical Discussions 9 July 5th, 2007 04:34 PM
VERY MODIFIED 1989 Range Rover FOR SALE TyziskBen For Sale - Vehicles 12 September 25th, 2004 10:46 AM
