V8 3.5 Fuel Leak - Defender Source
Old April 4th, 2016, 12:00 PM
Yorkie
Mark Whitehouse
1989 D90
V8 3.5 Fuel Leak
All
I've mentioned this before but I've now found a picture where I can show the problematic part.
The tube circled in Red has a hole in it. I have managed to complete a temp fix using epoxy and fiberglass matting (a radiator repair kit). But want to order a replacement part.
Can anyone help with a part ID on this?
Mark
Old April 4th, 2016, 12:40 PM
From the part catalog, it looks like the steel tube is integral with the carb. If it is not repairable, I would guess it is a press fit into the carb body.
The crossover piece is item 8: Allbrit.de - Ersatzteile fr LAND ROVER & MG ROVER
Part 612505 for the pipe with olive 614555 and nut 534790. All cheap and available parts.
You could also easily replace it all with a few fittings from a hardware store. A couple of tee compression fittings and tubing. It is probably all 3/8".
Old April 4th, 2016, 12:55 PM
Yorkie
Mark Whitehouse
1989 D90
Yes unfortunately its the tube that seems to be a press fit into the carb and therefore not easily replaceable. I suppose I will have to tidy up my temp fix into a more permanent fix and then eventually replace the carb(s).
Old April 4th, 2016, 01:16 PM
I don't see why the tube can't be replaced in the carb body. Is it leaking at the carb joint or at the compression fitting? If at the fitting, cut a bit off of the tube and install a new olive.
Old April 4th, 2016, 02:22 PM
Yorkie
Mark Whitehouse
1989 D90
There seems to be one or two pin prick type holes about midway down the tube.
fuel, v8
19J Fuel Pump Leak naw Defender Technical Discussions 2 July 5th, 2014 06:52 PM
Odd fuel tank leak tomaco1 Defender Technical Discussions 1 June 27th, 2013 09:12 PM
Fuel leak help javelinadave Defender Technical Discussions 0 February 14th, 2013 06:12 PM
110 fuel leak- how to remove these? Tyler Wirken Defender Technical Discussions 2 August 24th, 2012 05:09 PM
Weird fuel leak tomaco1 Defender Technical Discussions 4 March 14th, 2012 12:34 PM
