V-8 engine bracket and placement - Defender Source
Old February 24th, 2012, 10:01 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Has anybody done a diesel to V-8 engine replacement that has welded on the brackets for the V-8? on a 110. I have a 110 frame that had the engine brackets cut off. I think they were for a 300 Tdi but not sure. I am planning on putting in a V-8 so would need new brackets and locations. Thanks
Land Rover 110
Old February 24th, 2012, 10:12 AM
mattarm's Avatar
mattarm
Matt
1993 D110
Mine are comming off in a few weeks. Might be able to help.
Old February 24th, 2012, 11:29 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Yes I have some cut off brakets and can show you location with pictures and measurements.
legend in my own mind
Old February 24th, 2012, 11:53 AM
Mike-that green v8 110 is in the barn if you want to take measurements etc
Old February 24th, 2012, 02:47 PM
fwiw I usually buy new brackets from RN. They special order them and takes about a week but cheap @ $20 ea or so. For me it seems faster, better, cheaper, than me dealing with cut up stuff and the end result is better.
Old February 24th, 2012, 08:21 PM
Capt Milks's Avatar
Capt Milks
Thanks Guys. I do have a bud that has a V-8 110 that I can look at but was thinking it would be easier to get the measurements off a bare frame. I was hoping that somebody would have a template. I guess I will just need the brackets then. I found a place that will hot dip the frame as soon as I get it sand blasted. I will let everybody know how that goes.
Land Rover 110
Old February 25th, 2012, 02:04 PM
mattarm's Avatar
mattarm
Matt
1993 D110
My frame is bare. Can take whatever measurements you need.
Old February 25th, 2012, 11:01 PM
pendy's Avatar
pendy
jim pendleton
89'd90
See how the back of the bracket runs parallel with the back of the spring perch. That is how to line it up. As far as using a used bracket, guess it really just depends who cut the bracket off. I never have any probems reusing them.
Old February 26th, 2012, 07:55 AM
Capt Milks's Avatar
Capt Milks
Jim, Do you have some of the used ones for sale? I want to get the frame blasted and then galvanize it but want to make sure the brackets are installed prior. Thanks
Land Rover 110
Old February 26th, 2012, 08:04 AM
usadventureracing's Avatar
usadventureracing
Brett
110
I have a bare frame if you need measurements. Just let me know what you need.
1983 ROW D110
1970 Series III (Parting out)
ac, bracket, engine, rack
CO2 tank placement lobster Defender Technical Discussions 9 October 4th, 2007 07:38 AM
utility light bracket placement 97Ariesblu Defender Technical Discussions 2 June 29th, 2007 02:33 AM
