Using latest valley gasket.. - Defender Source
Old October 30th, 2007, 04:51 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
All the threads on the board indicate that hylomar and the right stuff need to be used in conjunction with the gasket. I was curious if that only applies to the old style because the company I ordered it from just said slap it on and bolt it down. If this is wrong where do I need to apply what? thanx
Old October 30th, 2007, 05:38 PM
Apply right stuff on the corners of the end seals. Also, buy new end clamps or make sure the ones you have are bent in such a manner as to apply adequate pressure.
Old October 30th, 2007, 06:12 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Sounds easy enough. thank you. No more sealing around the water inlets or whatever?
Old October 30th, 2007, 06:24 PM
In my experience, the techs never did that with the new valley gaskets. Make sure to put sealant on the bolt threads or use the updated bolts.
Old October 30th, 2007, 10:04 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, the techs replace the end clamps, bolts, gasket, end seals and put a liberal amt of right stuff at the four corners where the end seals meet the heads.
Old October 31st, 2007, 08:30 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
It is easy to understand why there is confusion because the manual says to apply hylomar to all of the surfaces but the guys are right, just do the corners.
Old October 31st, 2007, 09:04 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Will do. I don't have the updated bolts but I'll use thread sealer. Thanks for the help.
Old October 31st, 2007, 09:50 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Oh, I forgot, some of the techs spray that red loc-tite gasket sealer on the gasket where it meets the heads and intake. It isn't 100% necessary, but its a good idea. Don't spread right stuff over this portion though.
Old October 31st, 2007, 05:08 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Did i read right that a 1/2 inch bolt is supposed to be torqued to 90nm or 65 pounds per foot/ 760 pounds inch? Seems awfully tight for intake manifold bolts. By the way is there a way to tell if one has the updated bolts?
Old October 31st, 2007, 07:53 PM
I thought it was closer to 35 or 40 lb/ft. I am not sure about the updated bolts for the intake..
Old October 31st, 2007, 08:43 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
From the Workshop Manual
.................................................. ...........................................Nm lbf ft
FUEL SYSTEM - MFI
Air-Bypass valve (stepper motor) ............................................ 20 15
All flexible hose securing clamps ............................................. 1.3 1
Fuel feed pipe - hose to fuel rail .............................................. 22 16
Fuel filter .................................................. ............................ 31 23
Idle air control valve to plenum chamber ................................. 20 15
Plenum chamber to ram housing (bolts) ................................... 26 19
Ram housing to intake manifold (bolts) .................................... 26 19
Intake manifold to cylinder heads (bolts) ................................. 38 28
Intake manifold gasket (clamp bolts) ....................................... 18 13
Fuel filter inlet and outlet hose (unions) .................................... 30 22
Fuel pump to tank retaining ring .............................................. 48 35
Old July 21st, 2008, 08:17 PM
Whats the deal with the updated intake bolts? i dont remember if I used them when I did my intake?
gas
Saline Valley trip kellymoe Trips, Trails and Events 8 January 12th, 2006 05:39 PM
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
