Using headlight leveling switch (AMR5875) to activate ARB compress and lockers - Defender Source
Old September 4th, 2011, 01:25 PM
NomaD110
Christian
1993 Defender 110
Maybe someone here can help me,
A guy on the east coast told me that some guys in the UK re-wire the headlight leveling switch on their Defenders to do exactly what I am trying to accomplish.
My NAS defender 110 has a TD5 dash like so:
I am trying to use the headlight leveling switch to operate the ARB compressor and lockers. I am told that it essentially would work like so:
When on 0: nothing is on
When on 1: Compressor is on
When on 2: Compressor is on, front locker is on
When on 3: Compressor is on, front locker is on, and rear locker is on
I got the switch yesterday and so far with a tester it is not operating the way I was hoping. Inside it has resisters and simply adjusts resistance. Now I am finding that perhaps they might be changing the switch for a blower switch that simply makes connections to one of three different poles and doesn't heat up 1 AND 2 when switched to 2 for example. This would mean that I couldn't have the compressor on and the front locker just either or.
So I am assuming that I basically have the wrong switch or possibly could remove the resistors and make it work the way I want. Instead of reinventing the wheel I am hoping that someone has done what I am trying to do. Of course the goal here is try and avoid the after market switches and use a blank spot on my dash.
Christian
Old September 4th, 2011, 02:10 PM
T1G UP's Avatar
T1G UP
marcus
Puma 110 xs. Td5 110 xs for sale
can see it working like that.
and you'll need the rear locker in before the front
2011. 110 XS SW. 1999 TD5 110 XS SW Project For sale
Old September 4th, 2011, 02:15 PM
NomaD110
Christian
1993 Defender 110
Yes sorry that's what I meant.
Old September 5th, 2011, 12:50 AM
NomaD110
Christian
1993 Defender 110
Okay so after reading lots of forums it seems that I can not use a Land Rover style switch to do this. I confirmed that the blower fan only heats up the pole that its on. Does anyone know of a rotary style switch that maintains each of the previous poles hot as it turns to higher positions?
Old September 5th, 2011, 11:56 AM
waggoner5's Avatar
waggoner5
Gary Waggoner
1965 custom
Yep. 93-97 Landcruiser with factory lockers. Switch is available from Toyota
1963/2008 Defender Crew Cab
1965/1997 FJ45 Pick up
Old September 5th, 2011, 01:07 PM
NomaD110
Christian
1993 Defender 110
Thanks. I'll post what I end up doing.
Old September 6th, 2011, 02:47 PM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
My suggestion would be to use a Rover 100 (Metro) Heater Fan Switch YUK10003
This is a straight-forward - Off/3-Postion Rotary Switch, which is dimensionally identical to the Defender Headlight Adjuster Switch.
You can get one NEW on eBay UK (without Knob or Locknut) for 4.95 + 8.25 P&P to the USA
http://cgi.ebay.co.uk/METRO-HEATER-F...-/260209545290
ID:	41739 . Click image for larger version
The Knob and Locknut from a Headlamp Levelling Switch (which comes complete with them) will also fit the Metro Blower Switch, but the Blower Knob has just a white line on it instead of a Lamp symbol -
Alternatively, both the Knob and the Locknut have Rover Cars and Land Rover Part No's
Knob - Metro Heater/Blower - YUM10001 - 5.20
Knob - Discovery 1 Rear Aircon & Defender 50th Heater Fan/Aircon - YUM10001L - 5.64
Locknut - Metro Heater - YUN10001 - 0.01
Locknut - Discovery 1, Rear Aircon - YUN10001L - No Longer Available
Prices are from Rimmer Brothers - http://www.rimmerbros.co.uk/
Here's how the Blower Switch is wired -
Name:	Rover 100 - Heater Blower Switch Wiring Diagram.jpg
You could use this switch with 2 x Diodes, so that -
Position 1 - Feeds Terminal 6
Position 2 - Feeds Terminal 2 + Terminal 6 via the Diode
Position 3 - Feeds Terminal 5 + Terminal 2 via the Diode + Terminal 6 via the other Diode
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old September 6th, 2011, 04:01 PM
NomaD110
Christian
1993 Defender 110
Yes diodes are the answer. Thank you. I am going to order the stuff. Any recommendations on what diodes I should use?
Thanks.
ac, ht, switch
