using a tow bar on 84 d-90 - Defender Source
Old February 9th, 2014, 09:31 AM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
I want to tow my 1984 row d-90 with a tow bar (it has an LT77 transmission and LT230 transfer case). The distance that I have to tow the truck is about 5-7 miles. I would be using a tow bar and towing the d-90 with my 2013 Jeep Wrangler (the d-90 exceeds the towing capacity of my jeep by less than 100 lbs... no big deal). Anyway, do I need to disconnect the front or rear drive shafts on the d-90 to tow it without damaging the drive shaft?
Old February 9th, 2014, 10:21 AM
Transfer box in neutral should be fine. If it were an automatic, transfer box in neutral and transmission in park.
Old February 9th, 2014, 10:47 AM
I agree with jimmy for a short distance like that. If you were doing hundreds or thousands if miles I'd pull the driveshafts
Originally Posted by pendy
I'm here for the D's
Old February 9th, 2014, 11:05 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I've done thousands of miles like that no problem. The real concern is jack knifing. Make sure you come to almost a complete stop before making turns at an intersection. Otherwise the towed vehicle will push your rear end out from underneath you. If your tow vehicle were big like an rv this isn't a concern but when the tow vehicle and the one being towed are close in weight it can get scary. Remember, the vehicle being towed isn't doing any braking
Old February 9th, 2014, 01:06 PM
Wayne
wayne gayre
1997 D-90
Originally Posted by isleofbones View Post
i want to tow my 1984 row d-90 with a tow bar (it has an lt77 transmission and lt230 transfer case). The distance that i have to tow the truck is about 5-7 miles. I would be using a tow bar and towing the d-90 with my 2013 jeep wrangler (the d-90 exceeds the towing capacity of my jeep by less than 100 lbs... No big deal). Anyway, do i need to disconnect the front or rear drive shafts on the d-90 to tow it without damaging the drive shaft?
you never need to remove the drive shafts
Old February 9th, 2014, 04:21 PM
isleofbones
Mike Deery
1984 D-90
Thanks for the input. Does anyone have an idea for attaching a tow bar to the defender? Is there some time of ratchet strap bar or something?
Old February 9th, 2014, 09:09 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Most tow bars come with brackets, backing plates and 1/2" grade 8 bolts. You have to bolt the brackets though the front bumper, preferably in line with the frame rails.
90, d-90
D-90 Roll Bar Pads roverboy For Sale - Parts 2 November 16th, 2005 10:28 AM
Brush bar , Soft Top, Rear bench seat Rover- Girl For Sale - Parts 9 October 6th, 2005 01:51 AM
What do you tow with? ronward Defender Technical Discussions 19 August 27th, 2005 11:11 AM
Aux Light Mounting Bar mod4b Wanted 9 July 18th, 2005 01:48 PM
NAS SW entire roll bar kit sheki For Sale - Parts 4 September 30th, 2004 05:28 PM
