Using a multi meter to check Battery draw - Defender Source
Old December 19th, 2007, 05:15 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
How is this done? My truck has a dead battery in about 3 days if I don't use it.. I want to check and see if there is some type of draw. How is this done with a meter? I have one but don't know how to use it..
Legend in My Own Mind.
Old December 19th, 2007, 05:47 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
Set the meter for amps, and go through the fuse box. pull out one, put the 2 leads in the 2 prong receptacles for the fuse. The one that shows current is the one that draws down your battery.
I got your JEEP thing, now it hurts when I pee!!
Old December 19th, 2007, 07:42 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
undo the neg side complete the curcuit with the meter then pul the fuses
this way you don't have the pos of a short & have to get little things in tight spots
Old December 20th, 2007, 09:57 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
OK.. Peter, when I do that, should I still have it in the amps mode?
Old December 20th, 2007, 10:12 AM
I'm not Peter, but yes.
Old December 20th, 2007, 10:51 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
just make sure you have a fuse in your meter. I am sure you do but?!
report back
Old December 20th, 2007, 11:18 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Also, don't forget to move the red test lead from the Voltage input to the Amperage input on your meter.
Chance
battery
Battery Compartment under seat Flagg Defender Technical Discussions 11 May 15th, 2007 11:38 AM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
air meter voltage adjustment? Rod Hayward Defender Technical Discussions 4 July 24th, 2005 11:24 PM
