Using 300TDI Injectors in a 200TDI - Defender Source
Old April 17th, 2016, 11:14 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Am working on an experiment to use modified 300TDI Injectors in a 200TDI.
A few days ago, installed a new head gasket and a reworked cylinder head on a 200TDI engine.
Knowing that the spray patterns and pop-off pressure are identical or very close among the 200TDI and 300TDI decided to modify a set of 300TDI injectors to fit into the 200TDI head.
This required adding a collar to the 300TDI injector to make it the same clamping height as the 200TDI.
The 300TDI Injector lines must be used and the 300TDI hold down clamps.
Pictures attached...
Will update this thread after driving the 110.
ID:	147441   Click image for larger version
RDavisinVA
Old April 17th, 2016, 11:22 AM
xjahx's Avatar
xjahx
JAH
'93 NAS 110, '94 NAS ST, '85 90 PU
What is the benefit? Availability of 300tdi injectors compared to 200tdi? Cost? Proof of principle? Good experiment regardless.
Old April 17th, 2016, 11:36 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
According to my contacts at Bosh, 200TDI Injectors are NLS and when you find NOS ones they often cost 4 or 5 times more than a new 300TDI injector.
RDavisinVA
Old April 17th, 2016, 04:36 PM
I hope this works!
Old April 17th, 2016, 05:04 PM
xjahx's Avatar
xjahx
JAH
Keep up the work.
Old May 3rd, 2016, 01:22 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Works fine,
It may just be the fact that these are new injectors verses the old well used ones that came out, but seems like the 200TDI engine runs smother and has a little more power after being converted to use the 300TDI injectors.
RDavisinVA
Old May 3rd, 2016, 02:59 PM
Naplm00
Matthew
Hm. Neat. I wonder if a bolt on clamping collar like this would work?
Old May 3rd, 2016, 08:12 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Great work. We should send each one out to get flow tested. I don't have any injectors to have tested or I would do it.
Old May 8th, 2016, 08:56 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I don't think it would because of 2 things:
1.) The clamp cannot be so tight it pinches the hollow housing and effects the internals.
2.) The injector is slotted, so the spacer has to be flat on 2 sides, not round.
RDavisinVA
Old May 8th, 2016, 11:35 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Thanks for proving the concept!
Now, 300TDI injector fuel lines needed no modification to make this work?
Old June 6th, 2016, 10:24 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
We have about 400 miles on the new 300TDI injectors in the 200TDI engine and they work fine.
RDavisinVA
Old June 6th, 2016, 03:48 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Robert,
Are you going to offer theses as a kit then?
If so, what's the price? Will you offer with and without the collar?
Price savings over the 200Tdi injectors?
Thanks.
-Neil
Old June 7th, 2016, 09:50 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by steinhnj View Post
Robert,
Thanks.
-Neil
I will offer this as a kit for around $579.
While the price is aclose to a set of reman 200TDI injectors, you don't have the risk of loosing a deposit because of damaged cores.
Don't understand why, but even good mechanics can render an injector core unusable making the exchange scenario unsustainable.
Drew in Richmond made an adapter to use a slide hammer to pull out the 200TDI injectors.
This endures no damage to the crush washer surface for the small spill over banjo.
The nozzles on the 200TDI are getting expensive and the price keeps going up.
The 300TDI nozzles are cheaper, so if you need to rebuild the adapted 300TDI injectors in the future, the price will be lower and a damaged core more easily replaced.
RDavisinVA
Old June 7th, 2016, 10:01 AM
AdamSanta85
91' D90 200TDI
You could also sell your used 200TDI injectors as cores to recoup some expense.
Are we sure that the flow rate on these injectors is the same?
Old June 7th, 2016, 10:24 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I would issue credit for good 200TDI cores if someone wants to buy a 300TDI injector conversion kit.
According to the shop the nozzles have the same number of holes positioned symmetrically with the spray pattern very close if not an exact match.
This info is what lead me to the proof-of-concept to do the conversion.
RDavisinVA
tdi, 200tdi, 300tdi
swapping a 200TDI into a Series vehicle using the stock transmission cdb Series Technical Discussions 19 October 22nd, 2013 05:08 AM
200tdi injectors nozzle CDNRover Wanted 6 August 16th, 2013 03:23 PM
200TDI Injectors ajh Defender Technical Discussions 4 January 15th, 2011 01:19 AM
200tdi injectors? tomaco1 Defender Technical Discussions 2 November 23rd, 2010 02:56 AM
Source for 200tdi injectors? Hoosier Defender Technical Discussions 3 April 4th, 2009 11:42 AM
