Urgent Trailer Wiring Help - Defender Source
Old August 1st, 2014, 12:59 AM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
Hey Guys,
I'm leaving on a trip 4am tomorrow with a Uhaul trailer in tow (atleast I'd like to be). First time I've used my tow package... I picked it up today, and the guy tested the indicators and brake lights and said it all looked fine.
Later on my left rear d90 indicator goes out (turns out to be a loose connection on the bulb), but now I have reconnected the trailer, the trailer lights aren't playing nice.
- Only left trailer brake light comes on
- When I indicate left or right no trailer lights come on
- When I indicate left with my foot on the brake, the trailer brake flashes intermittently.
Double checked all the connections to trailer (4-pin). D90 brake and indicators are all working as expected.
Any suggestions of what I should look at?
Thx,
-Brett
Old August 1st, 2014, 01:07 AM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
Do you have one of the conversion boxes plugged in near your right brake light (underneath), and that's what your trailer lights pigtail runs from? If so maybe that connection is loose...It's black rubber, about the diameter of a quarter and an inch long...It plugs into the factory wiring harness for the trailer lights. Maybe a start...
Old August 1st, 2014, 01:48 AM
brettm's Avatar
brettm
Brett
yeah - has a rubber grommit around the joint. opened it up - was pretty tight and re-connected. didn't appear out of the ordinary. no change - thanks for the idea though. wish i had my multimeter
Old August 1st, 2014, 02:18 AM
brettm's Avatar
brettm
Brett
Confirmed it's not the Landie - must be a problem with the trailer. I wired a bulb across each output of the trailer socket coming out the Landie - and each pin worked as expected. Maybe Uhaul uses Lucas Electric on their trailers too....
wiring
FS: 25th Anniversary LWB (urgent opportunity) rrinsma For Sale - Vehicles 14 August 10th, 2015 02:48 PM
Urgent Help Needed with 300Tdi navydevildoc Defender Technical Discussions 167 June 11th, 2013 05:56 AM
Urgent need for motor slorocco Defender Technical Discussions 6 May 9th, 2010 09:15 PM
SLC Peeps - urgent rescue help needed! Tawayama Defender Technical Discussions 10 June 29th, 2007 11:44 PM
URGENT, HD MDE fronts w/ CV's needed RedRhinoProducts Wanted 0 February 7th, 2006 10:06 AM
