Urgent: need stud for manifold - Page 2 - Defender Source
Old November 8th, 2015, 10:55 PM
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
Take off the inlet pipe to your turbo. Does it look like or do this?
Pres - Florida Land Rover Club
Rovers 'n' Racing
407-720-9450
Old November 8th, 2015, 11:25 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
Yeah it is below the surface of the manifold. Nothing for it but removal of the manifold and yes hope for best that it is grabbable. Sent you a PM, Dan - thanks!!
Good point about the turbo bearing play, Scotty, and I too had feared that the turbo itself was bad. But mechanic's inspection on Sat checked that and pronounced the turbo sound.
He also pointed out that I am leaking oil from up near the top of the block, probably from the valve cover gasket. The left side of the block is wet with oil.
Old November 9th, 2015, 02:44 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Originally Posted by Talleyrand View Post
It seems like a bizarre thing to have happened, I can't recall hearing of this. Had anyone else faced this problem?
Cheers,
Yes, on 200, 300 and Td5
Old November 10th, 2015, 10:17 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
All fixed ..stud backed out gasket shifted and blew out .Had to make a new stud and swap around some hardware installed new gasket
ID:	134299   Click image for larger version
No Mall crawler here
Old November 10th, 2015, 10:23 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
nice
Old November 10th, 2015, 02:59 PM
Talleyrand's Avatar
Talleyrand
So grateful to Chris at Rovertek for doing this emergency repair at midnight last night after a full day at work. Just cannot say enough good things about his work and dedication to his clients. One in a million! For future reference in case anyone needs to know, the thread on those manifold studs is 1.50 (I could only find 1.25 at a parts store here so once again Chris had to pull a big rabbit out of the hat to mod a 1.50 bolt)
And big thanks also to Dan (ini88 ) for letting me grab his manifold gasket to get the repair done. Just feeling the D90 love so much today. I love all you guys : Cheers,John
2.5TD Cracked Exh Manifold? Missing Stud... icnsltmfg Defender Technical Discussions 3 April 26th, 2015 09:17 PM
URGENT: need an LT77 for a Camel trophy truck stuck in Richmond, IN JohnC Wanted 5 August 3rd, 2013 03:38 PM
Does one stud match up for another stud? airbornrover Defender Technical Discussions 2 May 11th, 2011 09:46 AM
Urgent need for motor slorocco Defender Technical Discussions 6 May 9th, 2010 09:15 PM
Broken exhaust manifold stud cgalpin Defender Technical Discussions 30 December 14th, 2008 02:02 AM
