Urgent Help Needed with 300Tdi - Page 9 - Defender Source
Old March 24th, 2012, 10:16 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
I was hoping to get a pic of a stock 300 Tdi to compare to/emulate.
Old March 25th, 2012, 04:46 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
From ECR site.
Google
Mike Hammond
Old March 25th, 2012, 04:51 PM
Originally Posted by mikeslandrover View Post
From ECR site.
Google
Damn that's one clean motor!
Old March 25th, 2012, 04:59 PM
mikeslandrover
Mike Hammond
From one of their build-up photo sequences.
http://www.eastcoastrover.com/206.html
Mike Hammond
Old March 25th, 2012, 08:18 PM
navydevildoc
Neill Thornton
That's what mine looked like when I bought it last year.... But then the seller owned a bunch of car washes, so I suppose it's to be expected!
Old March 25th, 2012, 08:45 PM
Neill, did you get yours sorted?
Old March 25th, 2012, 08:54 PM
navydevildoc
Neill Thornton
I will once I order the correct hoses. I have a new stock radiator and intercooler assembly to install, but I have to undo the hose mess that's there now. I also want to replace the timing belt since it has an unknown number of miles on it.
So once I get the hoses, it will be time to pull it all apart and make it happen!
Old June 11th, 2013, 05:56 AM
EMBOKO
mike
1994 300tdi panel van
overheating
i know this is a stale thread but for posterity and for other people wanting advise, i think it is good to chime in. in an earlier post you said you din not have a bleed screw in the top hose. it is there,that yellow thing in the elbow. Just out of curiosity, why did you have several hoses joined together anyway? that hump in that top hose was your air pocket, and was the reason you could not bleed the cooling system properly! that yellow plastic bleed screw is supposed to be the highest point in the cooling circuit. all air collects there and once you bleed it out, you are done. Like someone also sed, on an expedition vehicle, lose the e-fans and go with the factory spec one. Your life depends on it. for weekend blasts, do whatever you want, but not on an expedition/long trip. more gizmos are just an increase in the probability that something will go wrong.
Did you ever get the landie sorted out?
mike, kenya
Going to play devil's advocate on some of this...
When we pulled it all apart we flushed everything with the hose... the best we could do for the block/heads was run water from the heater supply hose back through, and it didn't have any problem flowing out of the water pump housing.
Also, my top hose does not have a bleed screw.
Similar answer to above, we flushed all sorts of stuff, and if it's coolant flow, why does it work great for hours on the freeway at high speed, then explode when at idle?
The first time it overheated I turned the fan on immediately and it was hot. Haven't replaced the water pump yet as all the parts are going to be special order and overnighted from somewhere at a price to match.
The expansion cap is an interesting suggestion. We ran it for a long time with no cap on, and then test drove it last night with it on but loose. No joy, still overheated. What would the cap have to do with it?
------ Follow up post added July 18th, 2011 08:08 AM ------
Mark, thanks man... yeah it sucks. Good news is that Cerrone's European, the sponsors of the LRR Forum, are about 20 minutes away. They might be able to pressure test it. I am going to call them, as well as Rovers North to see how fast I can get a head gasket kit.
300tdi, tdi
Needed - ST Roll bar pieces, dash 300TDI wiring harness CDeWan Wanted 5 July 9th, 2009 03:08 PM
SLC Peeps - urgent rescue help needed! Tawayama Defender Technical Discussions 10 June 29th, 2007 11:44 PM
300Tdi oil advice needed... Gkase Defender Technical Discussions 11 July 22nd, 2006 03:31 AM
URGENT, HD MDE fronts w/ CV's needed RedRhinoProducts Wanted 0 February 7th, 2006 10:06 AM
