Urgent Help Needed with 300Tdi - Page 3 - Defender Source
Old July 19th, 2011, 11:56 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Originally Posted by navydevildoc View Post
3 hole, as that's what was on there.
My dilemma now is what to do with a broken glow plug that will probably take a bolt extractor to remove. I started a second thread just for that.
Do you need to remove the plug?
I mean't what make/ composition gasket did you get?
Old July 19th, 2011, 12:05 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The 300Tdi is surprisingly easy to work on.
I keep saying that and people just don't trust me .
- Charles Eames
Old July 19th, 2011, 12:39 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Parts just arrived from Rovers North via FedEx. Headed to Zinola's, a highly recommended machine shop to remove the glow plug and check for warpage. On the way back going to pick up the 4 new glow plugs Winchester Auto Parts was able to find for me.
It's all coming together, this should be re-assembled and tested tonight.
Old July 19th, 2011, 01:14 PM
discotdi
Todd Miller
Land Rover
Old July 19th, 2011, 01:15 PM
outstanding!
Mark Kellgren
KM4BOR
Old July 19th, 2011, 02:25 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
To check for warping you can use a sheet of glass, in case
you don't have a good ruler.
- Charles Eames
Old July 19th, 2011, 02:27 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Since the head is off, you might as well fix the glow plug, but realistically, it has to be pretty cold to need them. Mine will fire up in 40 degree temps without waiting for the plugs to warm. 3 working glow plugs would be more than enough to get the engine to start.
I'm not advocating lax repairs, just a point of reference in case someone can't get a plug out and doesn't want/need to pull the head.
Tony
1984 110 "Smokey" (sold)
Old July 19th, 2011, 02:37 PM
navydevildoc
Neill Thornton
It's already at the machine shop getting removed and tolerance checked.
The real question now is if it's out of tolerance, the overhaul manual says it's done. However can I have it resurfaced and be good for a short while?
Old July 19th, 2011, 02:42 PM
thats a surprise. "done" should be defined as the bottom/base height of the head being too close to min thickness where shaving would reduce it to below min. i recently had my 2.8 head shaved as it was close to min but still enough.
Mark Kellgren
KM4BOR
Old July 19th, 2011, 02:45 PM
TS888's Avatar
TS888
Tony Sims
1984 110
I'm surprised there is no allowance for machining in the factory tolerance. That's pretty common on cylinder heads. Perhaps it's because of the high compression of the diesel.
Personally, I'd have it machined and give it a go. All you have to lose is a head that is technically no good, and a head gasket. IIRC it's not uncommon practice in the UK to have them machined. Maybe Diesel Jim can weigh in with another opinion.
Tony
Old July 19th, 2011, 02:48 PM
here is a relevant thread on the surfacing question. http://archive.difflock.com/discus/m...s/5/89992.html
i should also mention that when my shop was machined, they bored the injector holes a little to make up for reduced clearance from surfacing. uour shop should know that.
Mark Kellgren
KM4BOR
Old July 19th, 2011, 04:16 PM
kevkon's Avatar
kevkon
kevin
It's a matter of how much out of tolerance ( if at all) it is which in turn dictates how much stock removal is required. Ideally, you would only want to skim the surface to remove any distorions and provide the smoothness without altering the compression or valve clearances.
Old July 19th, 2011, 05:32 PM
navydevildoc
Neill Thornton
It was 5 thousandths out. He's gonna skim it and we will try.
NEW PROBLEM- The glow plugs the local place gave me were totally wrong. So now I have a gaping hole where the broken glow plug went. Rovers North is past their overnight cutoff, British Pacific doesn't have any.
Ship's Mechanical in Portland has some on the shelf, but doesn't have the time to overnight one. I am desperately trying to find a glow plug. Everything in the Bay Area (Local dealers [duh], Cerrones, and West Coast British) were not helpful.
Old July 19th, 2011, 05:37 PM
From what the others have said, it sounds like you can just plug it. Get a bolt the right size/thread and cut it to length
Originally Posted by pendy
I'm here for the D's
Old July 19th, 2011, 05:45 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Have you reached out to any of the local clubs?, RDS, TNTLR. Other TDi owners may have a spare in their stash?
navydevildoc
Neill Thornton
We are almost to that point. British Car Service in LA may have one we can scavenge.
Otherwise we will have to plug with a bolt.
------ Follow up post added July 19th, 2011 02:46 PM ------
NCLR for sure. In fact I had lunch with one of the BoD members yesterday.
Old July 19th, 2011, 05:48 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I have a 200 that is going no where fast.
I'd be happy to pull a plug if it will get you back on the road!
Old July 19th, 2011, 05:49 PM
plug it and deal with it as time allows later! not important right now.
Mark Kellgren
KM4BOR
Old July 19th, 2011, 05:52 PM
Plug the one that is easiest to reach later
Old July 19th, 2011, 05:53 PM
navydevildoc
Neill Thornton
PM forthcoming.
300tdi, tdi
Needed - ST Roll bar pieces, dash 300TDI wiring harness CDeWan Wanted 5 July 9th, 2009 03:08 PM
SLC Peeps - urgent rescue help needed! Tawayama Defender Technical Discussions 10 June 29th, 2007 11:44 PM
300Tdi oil advice needed... Gkase Defender Technical Discussions 11 July 22nd, 2006 03:31 AM
URGENT, HD MDE fronts w/ CV's needed RedRhinoProducts Wanted 0 February 7th, 2006 10:06 AM
