Urgency of replacing hub seal - Page 2 - Defender Source
Old September 13th, 2012, 06:56 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Originally Posted by DMSLongLake View Post
If I replaced every weeping seal, I would be broke!
Mine are not leaking enough, nor do I wade deep enough or often enough to worry...
lol and how much did you pay for your truck????I bought a disco cause I knew there was going to be maintenance involved
Old September 13th, 2012, 09:42 PM
Ray_G's Avatar
Ray_G
Ray Gerber
If it's leaking on the backside of the wheel over a prolonged period you're going to get fluid that eats the brake caliper's seals and then you're going to have more issues than just replacing the seal....
(as I found out on my previous D1).
r-
Ray
Old September 13th, 2012, 11:17 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Originally Posted by FSU_Disco View Post
I had a D2 prior to getting this so I'm familiar with Rover ownership. I'm planning on replacing the gasket, just do not have time before I leave for SAE and wanted to make sure I'd be fine
Depends how much grease has been slung out of the bearings. Don't want them getting hot.
ac
LT230T (20D) Input seal michael67 Defender Technical Discussions 5 August 16th, 2011 03:55 AM
Inner hub seal seating depth KevinNY Defender Technical Discussions 32 September 12th, 2009 02:05 AM
93 NAS D-110 Diff oil and Hub Seal Questions AHollander Defender Technical Discussions 16 October 23rd, 2007 02:46 AM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
