Upper mounted rear speakers - Defender Source
Old December 12th, 2013, 09:47 AM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
So I posed this question on the tail end of a speaker thread with little result - figured I'd give it its own thread and see if someone can point me in the right direction...
Looking for rear speaker housings that mount in the upper rear corners of a SW. I first noticed this on, if I remember correctly, murph's red 90. Haven't come across an option, but was hoping maybe some of you have.
As always, thanks so much in advance!
Cheers!
Aaron
Old December 12th, 2013, 09:50 AM
My rear speakers are upper mounted behind the alpine windows, but that is using the accessory speaker mounts that come with a LaSalle headliner.
Mark Kellgren
KM4BOR
Old December 12th, 2013, 09:59 AM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
This is what I have on my RoW SW.
I don't think it's quite what you're looking for but maybe it could give you an idea. Modified some kick panel speaker rings then riveted to the roof with some L brackets. I've enjoyed having the speakers up and out of the way
Old December 12th, 2013, 10:09 AM
the nice thing about having speakers high is they don't get muffled when you are fully loaded, and they are protected during any wading event.
Mark Kellgren
KM4BOR
Old December 12th, 2013, 07:57 PM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Mark - the headliner is cheating!! Although it may be a good excuse to buy a La Salle... I may be relegated to having something fabbed up, but I figured someone might have stumbled across a solution at some point. For the SW's the upper corners are loads better than where the factory decided to mount them.
Old December 12th, 2013, 08:00 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
I am also looking for this type of mount..
Defender 110
Old December 12th, 2013, 09:34 PM
There is no such thing as cheating in Darwinism.
Mark Kellgren
KM4BOR
Old December 13th, 2013, 02:45 PM
Mexican_Defender's Avatar
Mexican_Defender
Jose Bours
2012 Defender 110 (R.I.P.)
Have you considered adapting a Jeep sound bar? I'm sure that it would fit nicely over the rear door
http://www.ruggedridge.com/interior/sound-bars.html
Old December 14th, 2013, 07:46 AM
kinetic's Avatar
kinetic
Kinetic Adventures
TDI's
Thats actually not a bad idea... I may have a lead on another product that is possibly in the works for production. If anything becomes of it, I'll definitely post up the results. In the meantime, I may have to consider "evolving" with a snazzy fiberglass headliner...
Old December 14th, 2013, 09:08 AM
87 D110 (Ruby)
man....it is no wonder I see jeeps running around totally accessorized!!! Everything to buy is so inexpensive! If any of their stuff was for a LR I expect it would be double.
Old December 14th, 2013, 11:25 AM
Mexican_Defender
Jose Bours
The dimensions are not that far off between Jeeps and Defenders. With a little patience and imagination, I'm sure a lot of those accessories will fit a Defender quite nicely
Sent from my C6603 using Tapatalk
Old December 14th, 2013, 11:28 AM
draaronr's Avatar
draaronr
Here
LR3
Cheers!
Aaron
. We make a custom board that covers the whole area above back windows and doors. We cover it to match then put in 5.25s. Looks clean sounds great
Old December 14th, 2013, 02:11 PM
Pics?
Yeah pics. Sounds just what I need.
mount, speakers
Genuine Rear Upper Shock Mount SMac For Sale - Parts 8 September 21st, 2013 06:32 PM
rear light electiral hook ups paulb Defender Technical Discussions 25 January 19th, 2010 03:25 PM
Scorpion Rear Upper Shock Mounts enjoi1968 For Sale - Parts 2 December 5th, 2009 09:44 PM
SW rear door Upper hinge mightymg Wanted 3 October 3rd, 2009 07:17 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
