Upper Bulkhead Repair Question - Defender Source
Old April 12th, 2011, 07:47 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
There is some corrosion on the bulkhead just below the windscreen, just above one of the vents. The rest of the bulkhead is pretty good (I have welded in new corners several years ago). Does anyone make repair pieces to weld in for this area similar to the corner replacement pieces? If so, can you refer me to a supplier?
Old April 12th, 2011, 08:39 PM
Yes.
http://www.simmonites.com/DEFENDER%20BODY%20PANELS.htm
Others make them as well.
Old April 12th, 2011, 10:13 PM
isleofbones
Mike Deery
1984 D-90
Thanks for the referral. I've already reached out to see if they can supply and ship the repair section that I am seeking.
Old April 12th, 2011, 10:14 PM
Roversnorth might have them too.
Old April 13th, 2011, 03:18 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Simmonites likely buys them from YRM Metal Solutions. Go to the source.
http://www.yrm-metal-solutions.co.uk/index.asp
Tony
1984 110 "Smokey" (sold)
series bulkhead repair orionpco Series Technical Discussions 9 July 21st, 2010 02:27 PM
200tdi Build Question regarding bulkhead fitting Turbofan Defender Technical Discussions 12 October 21st, 2009 01:59 PM
Lift gate upper hinge bracket pictures / question dave_lucas Defender Technical Discussions 7 May 21st, 2009 12:07 AM
Bulkhead LH footwell repair panel? turbodave Defender Technical Discussions 1 August 22nd, 2008 03:03 PM
Bulkhead repair 61rover Defender Technical Discussions 1 May 19th, 2008 03:33 PM
