Upgrading the Alternator wire on my 300tdi - Defender Source
Old September 14th, 2015, 10:35 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My P-gaskets needs replacing so while its all apart I was going to replace my old 65A alternator with a 100A alternator I purchased some time ago. I've been told to upgrade the thickest wire leading to the alternator to at least a 8 Gauge. I'm not that familiar with the engine harness layout and I know very little about wiring in general so before I head over to West Marine for cable I thought I'd post up here first.
My brown (thickest cable on alternator) goes counter clockwise around engine (on top) connects with a whole bunch of various things before it connects to the starter. Does this sound correct? Looks like I would need about 5 feet of wire. Because this wire lays on top of the engine it has a heat shield wrap. If I can't reuse the existing one what would you use? I have a bunch of fiberglass mesh hose meant for this stuff but I thought I'd get some heat shield tape on it first What brand of heat shield tape do you recommend?
Is there any other wire I should upgrade while I'm in there? How about the wire from the starter to the battery? Also, Ancor (my preferred choice) doesn't have brown cable, only black, red, green, red, white and yellow. If I wanted the correct color what would it be?
Old September 14th, 2015, 10:45 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
If you have time to go mail order, try here for your wiring and connectors: Marine Grade Wire, AWG Tinned Copper Boat Cables Made in USA Genuinedealz.com Grumpy Bill's go to place. I'm sold on them as well. There is a WM walking distance from my slip that I support while kicking myself for not being better prepared b/c of their absurd prices.
Old September 14th, 2015, 10:58 AM
The main power wire goes from the alternator to the starter solenoid where the main lead from the battery connects. I would use 4 gauge welding wire.
Old September 14th, 2015, 11:14 AM
tpond
Toby Pond
110
Yes Carl, the brown wire is the one that you are upgrading. I did it on my truck, so you are welcome to come check it out. I took apart the old harness, and remade it with the larger wire. I would also be happy to help you do it if you would like a hand.
Old September 14th, 2015, 11:26 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Subscribed...
Old September 14th, 2015, 11:35 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I will likely take you up on that, Toby. what heat shield products did you use? Did you also upgrade the starter to battery wire?
Old September 14th, 2015, 11:36 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I will order from them if I have time to wait for it to arrive. Thanks!
Old September 14th, 2015, 11:37 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
What did you use for heat shield?
Old September 14th, 2015, 11:42 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
IIRC brown is the correct color. But someone should check a manual if you want to be sure.
Red is universal for hot wire though!
I would think 6 gauge should be more than enough.
opinions vary but I'm a big fan of crimp and solder.
Old September 14th, 2015, 11:51 AM
For the wire? It should not need a heat shield as it is nowhere near the exhaust. The insulation of the cable should be rated for engine temperature.
Old September 14th, 2015, 12:14 PM
To be clear there is no need to modify/hack into anything on the main harness. Simply add a heavy gauge wire as John is suggesting from the charge post on the alternator back to the positive post on the starter.
Old September 14th, 2015, 12:29 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm confused. I thought the idea was to replace the brown wire, not add an additional wire?
Is there exposed circuitry on the engine block? While trying to measure the brown wire I almost welded my tape measure to my engine block. Yes, I should always disconnect the battery. Need to get my OJOP connectors on there so it's not such a hassle.
Old September 14th, 2015, 12:39 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Adding another wire would be the same as going to one thicker wire. Depends on what you are going for, some people like the cleaner look of one.
The brown wire or the red wire from the starter to battery are hot. They are literally connected to the battery positive so if you bridge from alternator post or starter post to the block you're completing the path to ground.
Old September 14th, 2015, 12:48 PM
DC current travels on the surface of the conductor which is why dc wire is nearly always stranded instead of solid like AC. The more surface ie gauge, the higher the amperage capacity. By taking a single large gauge conductor from the alternator to the starter you have fixed the high amperage needs ie-most direct path to the battery. You can certainly cut into your existing harness and make the same upgrade, just pointing out that isn't necessary, as said it becomes a matter of personal preference. My opinion is that leaving the existing and adding a direct large gauge is more than simply upgrading the existing, and more is better.
Old September 14th, 2015, 12:57 PM
BlackField's Avatar
BlackField
Oscar
D110
I just did this on my 200TDi. Except I removed the brown wire completely as it was poorly spliced at one point and ran clockwise around the entire engine (maybe 4 feet or more of wire). I then added a new, shorter wire that went direct from my 120A alternator to the starter solenoid.
Old September 14th, 2015, 01:08 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Got it, thanks! Rovers North did the harness install. It looks legit so I think I'll leave it be and add a much shorter, addition wire as suggested. While I'm at it should I get a thicker gauge between battery and starter as well? Not sure what is on there currently.
Old September 14th, 2015, 01:16 PM
You should not need that. It is sized for the starter current, which is hundreds of Amps.
Old September 14th, 2015, 11:20 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Carl, since you're out here on the coast, you can get everything you need at West Marine. Go for their Ancor marine grade stuff and get the proper marine grade terminals as well. You will need to crimp the terminals with a proper crimper; depending on the gauge, you can use a small hand crimper or one of the bigger ones that looks like bolt cutters. For 4 AWG, it's probably going to be the big ones. I bought my Odyssey battery at Battery Systems and they let me borrow theirs. Someone locally might have one. West Marine might have one to lend, as well. Brian did not, last I checked.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old September 18th, 2015, 06:08 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Can someone tell me what's going on here?
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Here's the new one.
300tdi, alternator, tdi
Upgrading a 130 for heavy duty goose neck horse trailering? hmmrbrg Defender Technical Discussions 14 April 29th, 2015 05:29 PM
Is it ok to run 4 guage wire from Alternator to battery? Neil McCauley Defender Technical Discussions 24 January 11th, 2011 02:34 PM
Upgrading Battery Cables - Lengths? priest944 Defender Technical Discussions 0 January 7th, 2009 06:59 PM
94 D90 wire harness & 94 A/C wire harness mdmuf Wanted 1 August 24th, 2007 09:33 AM
Alternator wire shawnpalmer Defender Technical Discussions 23 September 11th, 2006 08:21 PM
» Defender Registry
White Ninety
gavin.
Rosco
Cal
Add your Defender
