Upgrading MOD lights? - Defender Source
Join the Defender Source Community Today
Old September 6th, 2016, 05:47 PM
DreamRover's Avatar
DreamRover
AJ
ROW 1984 D90
Hi all,
I am wanting to upgrade my MOD lights (screw in kind) and not sure how easy or possible this is. I am not really wanting to make holes for lights bigger if possible. Any help, part numbers for kits, or ideas is extremely appreciated.
Thanks AJ
Old September 6th, 2016, 05:51 PM
speedpin's Avatar
speedpin
Get any euro style light kit. ROW. Comes with all front and rear housings, pigtails, and lenses.
Unscrew mod lenses. Unscrew three little brass screws. Splice new wires, screw in housings and lenses.
Done.
I would consider civilian light finishers (surrounds) as well. Look at my mod 110 build. Thinks I posted the civ lights switch.
~ Semper Fidelis ~
Old September 6th, 2016, 06:03 PM
Just keep in mind the regular old style civilian lights are complete and utter crap. They are not water tight and break if you look at them.
If you go that direction, get LEDs. There are various options...
Old September 6th, 2016, 06:18 PM
If you want to pull the MOD lights, size wise the NAS is the way to go. Whether you go normal bulb or LED is your choice.
I'm biased to LEDs.
Old September 6th, 2016, 07:50 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
I did this the other day, just get the kit from rovahfarm, all the holes line up, you can splice them or connect the Bullets where the MOD lights were.
Old September 6th, 2016, 07:55 PM
RoverNY
Darrell
1987 Defender 90 ex-MOD
AJ, I am actually doing this update to my ex-Mod now. I found a set of RDX LED's from a vendor called Bolt on Bits. All the lights came with s/s hardware and all of the fittings and connectors. The diameter of the lens look like they will drop into the military style shield's. If you wants some more information let me know.
Darrell
Old September 6th, 2016, 07:58 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Originally Posted by DreamRover View Post
Hi all, I am wanting to upgrade my MOD lights (screw in kind) and not sure how easy or possible this is. I am not really wanting to make holes for lights bigger if possible. Any help, part numbers for kits, or ideas is extremely appreciated. Thanks AJ
Just be sure if you order the plastic surrounds you get the ROW version. Ask me how I know the NAS version has holes that don't line up
ht, lights, mod
Upgrading door latches... What to do about door cards? adamclyde Defender Technical Discussions 4 March 1st, 2016 10:38 AM
Upgrading the Alternator wire on my 300tdi Manimal Defender Technical Discussions 21 September 19th, 2015 09:07 PM
Upgrading a 130 for heavy duty goose neck horse trailering? hmmrbrg Defender Technical Discussions 14 April 29th, 2015 04:29 PM
Upgrading Battery Cables - Lengths? priest944 Defender Technical Discussions 0 January 7th, 2009 05:59 PM
